these would be the way to go... i used just regular aluminm water bottles
Pre-mixing on the road?
- fastplastic
Re: Pre-mixing on the road?
http://www.rei.com/product/783963/msr-f ... p-30-fl-oz
well not anymore but i did and worked great till the gas swelled the cheap plastic so bad it wouldn't screw on anymore.... NOT recommended!
- Dio89Elite
I use the same kind of premix bottle. If I'm going to go longer distances (depending on the distance between gas stations) I'll carry a one or two gallon gas can and some (quart) premix. I put in premix first then the gas in one or two gallon increments. My daily driver I have a very tiny gas tank (SB50), so when it's close to empty I just put in premix and then add the gas. I usually will have an error margin of up to 0.03 to 0.05 gallon. My engine hasn't blown yet with this error margin. On this I premix for 0.75 gal.tru72 wrote:Here in hawaii we all carry a gallon gan can in our bucket and also one of these.. the measurement are is 1 oz, I also seen smaller ones that are 1/2 oz per so its easy to use. I bought mines from walmart and just dumped out what ever was in it!
Aloha
D
I have a set of three 8oz bottle filled with oil that I keep in my backpack and a one gallon can on the back of my scoot. Definitely need it when I do the 4 hour trek to NH to see my GF every weekend.
Oh what you say is true, it is call essential tremors and it is from exposure to Agent Orange, but I had spills as a youngster too, usually from inattention, but spills none the less.fastplastic wrote:us younger guys are not so shaky so no mess(gotta give you a hard time lol)
I have a 10L fuel can premixed at home that I top the bike up with but I also carry a pre-mixed 5L can on my luggage rack for emergency sitations!
How ever if I do need to premix on the road I always have a 1L bottle of oil in the under seat storage and use a LARGE syringe with measurements on it to get the correct ratio.
Honda DJ1R project
Honda DJ1R project
Never heard of the syringe thing before, but it is a d*** good ideal.NZHonda wrote:I have a 10L fuel can premixed at home that I top the bike up with but I also carry a pre-mixed 5L can on my luggage rack for emergency sitations!
can recycle 2 oz plastic. carry a couple under da seat. 1/2 gal gas and 1 bottle oil. 32:1 no thinkin
....credit ZombieshopNashville with introducing this 50ml fuel-friendly 2T oil vial through the rally packs during Dead Peds annual R.I.P. Rally....pre-mixing made easy ...
- Sam Visit 006.JPG (164.49 KiB) Viewed 5912 times
This is how I roll. Amsoil in a aquafina bottle! 16oz=4 fill-ups!
94 elite 50s
66cc bbk
118jet/Pre-Mix32:1
1"uni-filter,Keli 9g
1k center,8.44 gears,ZX Trans
V8 Pipe,IRC MB38 80/90 tires
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
1" Uni-Filter,8:44gears
66cc bbk
118jet/Pre-Mix32:1
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
hahhaha ZMUD that looks like an old pee bottle
Mystic wrote:hahhaha ZMUD that looks like an old pee bottle
94 elite 50s
66cc bbk
118jet/Pre-Mix32:1
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
66cc bbk
118jet/Pre-Mix32:1
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
I don't pre-mix but I saw a post once where the member used the existing oil tank to carry his oil. Rigged up an on-off valve in the hose and just carried an empty measuring bottle. Not sure where he ran the hose for access, but seems like this would be a good back-up method for emergencies if nothing else.
'83 Aero NH80
'87 Elite SE50
'70 CT90
'72 CT90
'73 CT90
'74 CT90
'83 Aero NH80
'87 Elite SE50
'70 CT90
'72 CT90
'73 CT90
'74 CT90
I'm picturing a valve like this one (red cap to prevent leakage). Obviously the trick would be to find an easily accessible place to mount and run the oil hose to it.
'83 Aero NH80
'87 Elite SE50
'70 CT90
'72 CT90
'73 CT90
'74 CT90
'83 Aero NH80
'87 Elite SE50
'70 CT90
'72 CT90
'73 CT90
'74 CT90
Now there is a real accurate measuring system........................NOT!ZMUD wrote:This is how I roll. Amsoil in a aquafina bottle! 16oz=4 fill-ups!![]()
That's what I use for a emergency fill-up. And imagine that another NEGATIVE REPLY by The site D.I.C.K!....How you havent got banned yet is beyond ME!Bear45-70 wrote:Now there is a real accurate measuring system........................NOT!ZMUD wrote:This is how I roll. Amsoil in a aquafina bottle! 16oz=4 fill-ups!![]()
94 elite 50s
66cc bbk
118jet/Pre-Mix32:1
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
66cc bbk
118jet/Pre-Mix32:1
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
