Source for a cylinder/piston kit for a 1983 urban express
Buckeroo Bob
Post by Buckeroo Bob »
Low compression on 1983 Nu50. Rather than bore to next oversize, the customer want to fit a new cylinder/piston kit. Any suggestions? Is the Nu50 set up interchangeable with any other scooters?
And the guy at the scooter shop told me that there was noting I could do if the compression was low. Tsk, tsk! I knew better.
Buckeroo Bob
Source for 1983 Urban Express new cylinder/piston
Can anyone tell me the best place to get a new cylinder/piston kit for a1983 NU50? Are other models compatible? Or might it be cheaper to bore out to next oversize and just replace the piston on this particular scooter? Thanks.
Re: Source for 1983 Urban Express new cylinder/piston
Buckeroo Bob wrote:Can anyone tell me the best place to get a new cylinder/piston kit for a1983 NU50? Are other models compatible? Or might it be cheaper to bore out to next oversize and just replace the piston on this particular scooter? Thanks.
i believe honda hobbit and honda express engine parts are interchangeable
I, too, believe that you should research the kits available from sites like: treatland.tv ..or...1977 Mopeds... :wink: ....not only big bore kits, but then pipes, intakes, carbs
martynkim
Post by martynkim »
motormike wrote:I, too, believe that you should research the kits available from sites like: treatland.tv ..or...1977 Mopeds... :wink: ....not only big bore kits, but then pipes, intakes, carbs
treatland.tv is the best resource
z50r-ghost
Post by z50r-ghost »
+3 on treatland... Benji (owner) is one cool dude that ships stuff faster than anyone else!
j
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
Buckeroo Bob
Thanks. That's just what I did and you are correct, they are extremely helpful and I have placed an order and it is on its way! Hey, hey, hey!
