Pre-mixing on the road?
Re: Pre-mixing on the road?
I still say it looks like there is some funky pee in that bottle hahah
I don't get banned because morons like you need to be ridiculed for being STUPID!ZMUD wrote:That's what I use for a emergency fill-up. And imagine that another NEGATIVE REPLY by The site D.I.C.K!....How you havent got banned yet is beyond ME!Bear45-70 wrote:Now there is a real accurate measuring system........................NOT!ZMUD wrote:This is how I roll. Amsoil in a aquafina bottle! 16oz=4 fill-ups!![]()
Oh!...OK...Thanks.Bear45-70 wrote:I don't get banned because morons like you need to be ridiculed for being STUPID!
94 elite 50s
66cc bbk
118jet/Pre-Mix32:1
1"uni-filter,Keli 9g
1k center,8.44 gears,ZX Trans
V8 Pipe,IRC MB38 80/90 tires
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
1" Uni-Filter,8:44gears
66cc bbk
118jet/Pre-Mix32:1
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
Only a fool would think oil in a water bottle makes for a accurate mix. Idiots that think their eye makes for an accurate mix are what ruin their scooters and give bad advise to others.ZMUD wrote:Oh!...OK...Thanks.Bear45-70 wrote:I don't get banned because morons like you need to be ridiculed for being STUPID!Keep ruining this site and you'll be the only one left to call STUPID!
" Ignorance is the absence of knowledge. Stupidity is the presence of knowledge and the refusal to use it."
'89 Honda Elite SB50p STOCK
its not rocket science fellas..... i cary one of these http://compare.ebay.com/like/2808782333 ... s&var=sbar and a qt. of this http://www.rockymountainatvmc.com/p/43/ ... z.?ref=gmc on me every where i go. That way i can mix no matter what i want my ratio to be.
- steffen707
I downloaded a sweet app on my android phone called 2 stroke gasoil mix calculator by HENYO, it cost .99, but the cool thing is that when it calculates from US gallons used, it will output both US ounces and milliliters. Every other free calculator on android did not do this. One claimed it did, but when I put in 1 gallon of gas at 32:1 it said i needed 3700milliliters, which is way off. I know 1 gallon and 4 ounces of oil is very easy to calculate, but at .8gallons, its more accurate to use milliliters than ounces.
The cool thing about this app is that when you fill up at the gas station you don't always fill up in .5 gallon increments. So just fill it up, throw the number in the calculator and use a measuring syringe to accurately get the ratio you need.
There's an online calculator i found that's free. http://www.csgnetwork.com/oilfuelcalc.html This does the same thing, but if you don't have data coverage and want to use it, no luck. That's why I bought the app for .99
87 Honda Spree,
XX Yamaha YSR50
92 Yamaha Jog -> Stock.
05 Kymco Super 9-> My cruiser
XX Yamaha YSR50
- Trafficjamz
How do you measure the oil with a water bottle?
have you made marks on the bottle? or just eyeball it?
Some good ideas in the thread
- We'll put them up on the 'wiki shortly
For the portion of thread morphed to 'global warming' it's over in chit-chat as this link
Tenacious T
So back in the 60's early 70's of snowmobile riding in northern Michigan ,long before oil injection you could drive your sled to the gas station and they had pre-mixed gas at the pumps ! T
Chicago Ben
pretty sweet eh? hey Tenacious - I'm from Grosse Pointe originallyTenacious T wrote:So back in the 60's early 70's of snowmobile riding in northern Michigan ,long before oil injection you could drive your sled to the gas station and they had pre-mixed gas at the pumps ! T
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
WOW!....Are you Guys REALLY that ANAL about pre-mix'n?
I mean I like to have a exact mixture but getting down to Milliliters of oil per quart?......Come ON!
94 elite 50s
66cc bbk
118jet/Pre-Mix32:1
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
66cc bbk
118jet/Pre-Mix32:1
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
Oh lord... this thread got interesting.
Funny. I have the same situation on my stock Elite, where the pump died and I decided just to run it pre-mix rather than installing a new pump (I ground off the gear teeth and stuffed it back in.)
I carry a full 1 qt bottle. I can see through the sides how much oil I'm adding, and I add it in accordance to the amount of gas.
32:1 is 1 oz per .25 gallons. Not that hard. If I dump in too much or too little? Frankly, running 50:1 or 25:1 on a tank isn't going to kill the engine or the plug.
Admin, Hondaspree.net
Finally someone that understands!noiseguy wrote:32:1 is 1 oz per .25 gallons. Not that hard. If I dump in too much or too little? Frankly, running 50:1 or 25:1 on a tank isn't going to kill the engine or the plug.
94 elite 50s
66cc bbk
118jet/Pre-Mix32:1
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
66cc bbk
118jet/Pre-Mix32:1
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
- patthesoundguy
I have premixed for thousands of KM, no troubles. I carry a small bottle that holds 100ml of oil graduated into 10 ml increments, and I just carried a small calculator and did the math for how much gas I put in for the given ratio I required for the bike, real simple. Then before the smartphones I had a HP pocket pc that had excel in it so I figured out how to write an excel program that had the ratio and litres boxes just like the free android app does now. Now I use the android app. I try not to have to mix on the road but sometimes you have to. I have been spoiled by the oil injection on my spree but have to premix my express. Oil injection is a great thing.
