94-01 sa50 belt
thekingof7
- Goped
Re: 94-01 sa50 belt
One more thing for clarification
http://www.oreillyauto.com/site/c/detai ... yword=7240
This guy?
Thanks
This guy?
Thanks
- Dio89Elite
Re: 94-01 sa50 belt
Hey Mystic, the Gates 7240 that you spoke of is for the Spree?Mystic wrote:I dont think the 94-01 elite belt is the same as the belt for a Spree. You can go to the autoparts store and get a Gates belt for around 12 bucks that should work fine Gates 7240 pretty sure OReilly autoparts has them
Is there an equivalent for the 94-01 SA50? Thanks.
Re: 94-01 sa50 belt
yes but i cant remember the gates number right off hand i can post it tomorrow I kept the cardboard
thekingof7
- Goped
Re: 94-01 sa50 belt
Not sure about your second question, but to clarify the Gates 7240 is for the Spree.Dio89Elite wrote:Hey Mystic, the Gates 7240 that you spoke of is for the Spree?Mystic wrote:I dont think the 94-01 elite belt is the same as the belt for a Spree. You can go to the autoparts store and get a Gates belt for around 12 bucks that should work fine Gates 7240 pretty sure OReilly autoparts has them
Good Luck!
Re: 94-01 sa50 belt
The Gates number for the sa50 94-01 belt is PL20110 (641x15.5x30) for the regular not sure about the number for the Premium belt that sell for the elite
Re: 94-01 sa50 belt
As far as i know gates does not make belts for scooters, there is an rpm range also due to ins. they will not cover your death, go cheap or go fast and live to tell about it
- Trafficjamz
Re: 94-01 sa50 belt
no that is for the elite/ dio cvt transmissionthekingof7 wrote:Thanks for the advice, I'll give that a shot.
Just curious, http://www.ebay.com/itm/180652709015?ss ... 1423.l2649
I'm assuming this is the same seller, but aren't the belts advertised specs matching of the sprees requirements? I am a bit new at this.
-Cheers
Re: 94-01 sa50 belt
As I cannot seem to tell the difference... This belt is under the Honda Elite SA50 / SR50 /SK50 1994-2001 Parts section of this site:
Malossi 61 7215 kevlar belt for Honda DIO (HSC SC01)
http://www.spi-parts.com/scooter-parts- ... sc-01.html
Honda DIO 3 ZX Live, Malossi, WindJammah!
Re: 94-01 sa50 belt
Hi. anyone know the polini belt number for 94-01 elite? is it 248.002?
how about the SYM 23100-GR1-0030? thanks.
Re: 94-01 sa50 belt
Also the part number for the Polini variator that fits the 1994-01 SA50 Elite .
- paulpauly7
Re: 94-01 sa50 belt
Wow what a ramble of repeated sentences .So did you fix you slide guides breaking or not ? I never heard of them breaking also run your cvt dry (no lube or grease) .
