Honda spree clutch longevity
lovemyelite50
Post by lovemyelite50 »
Hello I was wondering how often (miles wise) you should half to change the clutch? Thanks.
Re: Honda spree clutch longevity
Service manual
http://www.hondaspree.net/other/Spree_NQ50_84-87_1.pdf
Section 3-2 and Section 8-10
indetrucks
Post by indetrucks »
Does that service manual say how to change the oil?
I can't seem to find it....
Bear, can you post the section for me like you did for him?
:P
-Christian
Section 3, Maintenance.
indetrucks
Bear45-70 wrote:Section 3, Maintenance.
Section 3 ... what?
Is says how to check the oil but no where does it state how to drain and refill the oil.
Bear, can you help out??
You started to help out in this thread:
viewtopic.php?f=3&t=22914
:hi:
-Christian
There is an index and if it is not there it will be in Section 2 Lubrication.
Section 3 ... what?
:hi:
