AX24 belt on 88 Elite E
Duke
Post by Duke »
So I ordered a couple of cogged Goodyear AX24's off amazon and I can't get them to work on my SB50's. It rides too high on the rear pulley and drags on the gearcase inside. I tried getting it into the groove by spreading the pulley halves but they come back together pushing the belt out. Am I doing something wrong? I guess I am realizing now these aren't a DIRECT replacement for the Honda Bando as they are wider. Does that mean a higher top speed with a slower takeoff? Because the takeoff is slow enough as it is...
Also wondering about how the rear pulley functions on these. Is it supposed to squeeze the belt and keep it in the same position or does is vary with speed like a variated pulley. Anyone care to elaborate???
Anyway here's a pic of my latest acquisition. 1-owner, 1600 original miles :D
87 Elite 50
99 Aprilia SR50 Carb polini
1973 Suzuki TS185 smoker!
2002 KTM Duke
abreen89
Re: AX24 belt on 88 Elite E
Post by abreen89 »
i too ordered a ax 24 off of amazon and it rubbed... pathsoundsguy has had success with the ax24 he order from grainger.com i think im going to order that one and try it. The ax24 is a wider belt making your buttom end a little slower but giving your top end a few more mph...
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
abreen89
Post by abreen89 »
this is the one i bought that rubbed http://www.amazon.com/dp/B004HFRW6O/ref=biss_dp_t_asn
this is the one pathsoundguy bought and it worked for him http://www.grainger.com/Grainger/DAYTON ... Pid=search
im not seeing any difference in dimmensions so im not sure... but mine too rides way high on the pulley and just rubbed the whole time...
patthesoundguy
Post by patthesoundguy »
are the scooters variated that the belts are going on? My spree was a bolt on and go operation. Im figuring that the ax24 might just be a little too long to have the tension needed to keep the belt riding low enough in the driven pulley on the scoots you are trying them on. There is not much else that can be wrong to make the belt ride too high, that I can think of.
abreen89
Post by abreen89 »
patthesoundguy wrote:are the scooters variated that the belts are going on? My spree was a bolt on and go operation. Im figuring that the ax24 might just be a little too long to have the tension needed to keep the belt riding low enough in the driven pulley on the scoots you are trying them on. There is not much else that can be wrong to make the belt ride too high, that I can think of.
no the sb50p duke is trying and the honda spree i am trying are both NON variated and mostly identical to your engine the only conclusion i can come up with is that the belt on amazon is some how different then the grainger???
Duke
Post by Duke »
Looks like I will be ordering a couple of Bandos... :oops:
87 Elite 50
2002 KTM Duke
abreen89
Post by abreen89 »
Duke wrote:Looks like I will be ordering a couple of Bandos... :oops:
bandos>?
zuphilius
Post by zuphilius »
bandos>?
Stock Honda belts.
patthesoundguy
Yeah I was just making sure. in the next few days Im going to have my belt cover off to repaint it again Ill have a look and make sure there is nothing Im missing when i have it apart.
az_slynch
Post by az_slynch »
Funny, I was just pursuing this issue...
The Dayton AX24 belt measures (according to Grainger...) 5/16" deep, or .3125" inches. I just received a Goodyear AX24 in the mail today, saw this thread, and measured the depth with a set of calipers; it measured between .335" and .340" on ten different tooth samples. My guess is that the Goodyear belt is a bit thicker in the depth dimension. On the thinner samples, it was .020" inches (roughly .5mm), which could be just enough of a difference to rub.
Aside from getting the Daytona belt, the next easiest fix might be to clearance the casing a bit with a file or rotary tool. Here's what I found when I looked at the pulley...
The driven clutch on the SB50P is slightly different than the Spree. Both bikes are fixed gear, but the driven clutches and pulleys are different. I pulled out both units ( I had recently rebuilt an '85 Spree and a '90 Elite E driven clutch) and did a quick "stare and compare" on them. The ramp angles on the SB50P are sharper at the periphery and the compressed pulley is about .015" thinner than the Spree pulley. Don't know how true each of my pulleys are, but I'd consider that to be a possible reason for "belt rides high".
The pulleys wont work like a typical CVT driven clutch. While similar in construction, both of these units use a very stiff spring to prevent the pulley halves from spreading under acceleration loads from the belt. On the SB50, it has a toothed plate that passes though both pulley halves in order to keep them from slipping in relation to one another or pulling apart.
It might be possible to dismantle the driven clutch and insert a few thin shims between the pulley halves, but I don't know if this would cause the belt to ride too loosely. If you wish to experiment, there's a Piaggio tool for moped clutches that works pretty well for assembling and disassembling single-speed Elites and Sprees:
https://www.treatland.tv/olympia-vespa- ... puller.htm
I'll look into this further once I get engine bits back from the machine shop. I was looking at the AX24 mod too as part of an attempt to squeeze a bit more speed out of an SB50P without kitting; it's not my bike and it has to be reliable enough for a new rider and capable of touching 35mph.
'64 Vespa 90 (V9A1)
'65 Allstate Compact (DS60)
'74 Vespa 125 Primavera (VMA2)
'81 Vespa P200E (VSX1) (2)
'83 Yamaha Riva (XC180K) (2)
'84 Yamaha Riva (CV80L)
'85 Honda Spree (NQ50)
'86 Honda Gyro S (TG50)
'87 Honda Elite (CH80)
'89 Honda Elite E (SB50P)
abreen89
Post by abreen89 »
az_slynch wrote:Funny, I was just pursuing this issue...
good info so it sounds like the dayton has more clearence then the good year ill be purchasing a dayton
Duke
Post by Duke »
Thanks AZ, that's some informative research right there. I certainly thought about shaving the case a little as there is just one bump at the rear pulley where it rubs. I just wasn't sure how thick the case is back there and just how much clearance that belt would need back there. Do you reckon there is much variance in how high the belt rides in the rear pulley due to different speeds? I am still using the OEM belt which is surely as old as the scoot (88) and it barely reaches 30 mph...
87 Elite 50
2002 KTM Duke
Bspree
Post by Bspree »
wow i just installed a az24 belt and it works great , my scooter has a 68cc big bore kit and the belt works perfect
Bspree wrote:wow i just installed a az24 belt and it works great , my scooter has a 68cc big bore kit and the belt works perfect
The size of the engine has nothing to do with the belt fitting or not.
abreen89
Post by abreen89 »
what kind of scooter did you install it on and what brand of belt did u get?
