Sym dd50 build!!
kauaianman
Re: Sym dd50 build!!
i wish running too cool was my problem
Sym dd50 build!!
Ok finally an update I have this little b**** of a project completed and am finally really happy with the results!!
Got it tuned with a 45 pilot and a 118 main with needle clip in the middle!
Runs like a bat out of *. Not sure of top speed as there is nowhere I can safely do a top speed run here but it's way fast enough! Keeps up and out accelerates all the 125 4stroke scooters here. So I'm happy.
So my next project will be a DIO af18 naked with a 75, 48mm bore or another 50mm not sure yet but I'm gonna get to that in a month or two!
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
- paulpauly7
theres some cheap dios up for sale there i just bought a af28 dio zx for 12000yen in osaka its a little ruff but run and no missing parts
kauaianman
what carb with that jetting? 28?Madman wrote:Ok finally an update I have this little b**** of a project completed and am finally really happy with the results!!
is that with the ministroke 50mm?
Sym dd50 build!!
21mm carb with standard crank stroke!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Sym dd50 build!!
And some pics of the build to date!
- ImageUploadedByTapatalk1343909083.786904.jpg (73.9 KiB) Viewed 4731 times
- ImageUploadedByTapatalk1343909061.132595.jpg (68.95 KiB) Viewed 4731 times
- ImageUploadedByTapatalk1343909028.150183.jpg (69.08 KiB) Viewed 4731 times
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
