i used a bmx handlebar clamp with a custom made shim because the bmx stem is about 1/8' bigger than the scooter's
if you were wondering, the disk front end is a complete bolt on, but i swapped out some parts
will be throwing on a headlight too, either on the front panel or on the bar. what do you suggest?
its not on the ground because i got a flat front tire
sorry, not the best pic, was in a rush
