87 honda elite 50 boggs and wants to shut off
87hondaelite50
Post by 87hondaelite50 »
i have a 87 honda elite starts with kick start fine, runs good but when i get to a stop sign and slow down to a stop it wants to shut off!!! other then this it runs great.. here is the link to my build post http://www.hondaspree.net/phpBB3/viewto ... 16&t=24404
also may need my carb adjusted but idk
87 Honda Elite 50 Saved from The Junk! YES!
martynkim
Re: 87 honda elite 50 boggs and wants to shut off
Post by martynkim »
87hondaelite50 wrote:i have a 87 honda elite starts with kick start fine, runs good but when i get to a stop sign and slow down to a stop it wants to shut off!!! other then this it runs great.. here is the link to my build post http://www.hondaspree.net/phpBB3/viewto ... 16&t=24404
Carb problem
87hondaelite50
does it just need adjusted or something more?
paulpauly7
Post by paulpauly7 »
that crapy pod filter you have aint gonna help.Its now running lean when your not at WOT thats assumeing you hav up jetted the main jet if not the your lean all the time
paulpauly7
go back to the stock air box this aint a 4 stroke its a 2 stroke
abreen89
Post by abreen89 »
Holy * dude we told u over and over agin I are going to run tooooo lean with th pod filter do u know what that means???? It means not enought fuel oil in the chamber and if that happens ure engine can seize.... There are two ways to fix this upjet (bigger main jet) or get the stock filter plain and simple tuning tips can be found in ure manual
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
87hondaelite50
One if you read my build post I do not have a oem air box that's why I had to get this one
Second I did not ask anything about if I had to upjet or not I know I have to do this..
And third please go back to school and learn to spell thank you
Post by swimmingfree »
87hondaelite50 wrote:One if you read my build post I do not have a oem air box that's why I had to get this one we dont remember your build post and with free help you shooed not get pi ss sy
Second I did not ask anything about if I had to upjet or not I know I have to do this..your post is 87 honda elite 50 boggs and wants to shut off... to small jet cood be what is going on your over heating the motor
And third please go back to school and learn to spell thank you spelling has nothing to do with what he is saying
87hondaelite50
My motor is not over heating also If you read above in my post I gave y'all a link to my build
I know spelling has nothing to do with what he is saying but at least spell right if your going to tell me what I already know thanks
how do you no your not over heating ????
do you have a gage???
have you done a plug crop??? lite brow is not good it shood be a dark brow
as for your other post you have been told that the motor will over heat becase your running lean and it will fry the motor
if you are going to not up jet the carb .. then tape off most of the air filter so it be richer mix
87hondaelite50
Yes I have a gauge thank you and I have plugged almost all of the air filter inside and it still wants to shut off
you may need to a just the carb when the motor is hot
87hondaelite50
What temp should I tune at?
dun rite
Post by dun rite »
this area is full of info http://hondaspree.net/wiki/index.php5?title=Main_Page in it you will find this http://hondaspree.net/wiki/index.php5?t ... ts_-_Spree Your engine should be totally warmed up when adjusting the carb. good luck
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
abreen89
Post by abreen89 »
Not tuning for temps you need to adjust ure idle screw in an probably ure mixture screw our ure shooting for 1800 Rpms but tuning will be pointless until u upjet
