what causes this to happen?
- Trafficjamz
Re: what causes this to happen?
Excessive heat on an air cooled engine looks like. Also known as a blown head gasket lol. Id say too much compression mixed with not enough octane. Is that 2 different head gaskets also?
- Trafficjamz
that is just one head gasket.LoveMyHonda wrote:Excessive heat on an air cooled engine looks like. Also known as a blown head gasket lol. Id say too much compression mixed with not enough octane. Is that 2 different head gaskets also?
Your probably right about the compression being too high......165ish
- Trafficjamz
Got these from Ebay.
Had to make my own holes.
Looks more durable to me.
Perfect fit.
I like that!
are those much thicker then the oem ones???
'89 Honda Elite SB50p STOCK
- Trafficjamz
yesabreen89 wrote:are those much thicker then the oem ones???
almost twice as thick.
Hmm did it affect your compression?
- Trafficjamz
I hope so....it was over 165 before.abreen89 wrote:Hmm did it affect your compression?
Compression should be about 150 now
I'll test it out tomorrow.
Cool let me know how much it affects it what size top end did u out it on?
Nice choice on the new gaskets. Very good find.
2006 Sachs Madass
- FTP 140cc Kit
2006 Xkeleton Trickster
- Lifan 90cc auto
- FTP 140cc Kit
- Lifan 90cc auto
- kingkamehameha
I assume your running race gas on this motor? Where can i get those copper ones for a smaller bore?Trafficjamz wrote:I hope so....it was over 165 before.abreen89 wrote:Hmm did it affect your compression?
Whats your squish going to be with that much more gasket? Im assuming youre at your max for port timing by raising the cylinder and the gasket is the only way to lower your compression at this point. double the head gasket and squish for certain is going to suffer.
Trafficjamz wrote:that is just one head gasket.LoveMyHonda wrote:Excessive heat on an air cooled engine looks like. Also known as a blown head gasket lol. Id say too much compression mixed with not enough octane. Is that 2 different head gaskets also?
Your probably right about the compression being too high......165ish110 octane race fuel.
yes he is..
- Trafficjamz
thank you.wiguy05 wrote:Nice choice on the new gaskets. Very good find.
http://www.coppergaskets.us/MCExamples.html
this company can make any size gasket you need. Any thickness too
I might have the make me a custom base gasket for my stroker
http://www.ebay.com/itm/YAMAHA-TD-3-COP ... _481wt_928
these are the ones i got. they are 55mm across, they are .032" thick
i think stock is around .020"
