dirtbikemikebike
Posts: 31 Joined: Fri May 12, 2006 11:58 pm
Post
by dirtbikemikebike » Thu May 18, 2006 10:57 am
Will an Aero motor fit into a Spree ? Will it fit nicely, or is there some modification to be made?
Posts: 4381 Joined: Sat Jul 31, 2004 8:00 pm
Post
by noiseguy » Thu May 18, 2006 10:58 am
That's a good swap. It will fit, you need to do some rework to the motor mount.
mopedman
Posts: 1213 Joined: Mon Jul 23, 1973 10:24 am
Post
by mopedman » Thu May 18, 2006 12:20 pm
yea you have to swich engine mounts
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
darat
Posts: 3132 Joined: Fri Jul 23, 2004 10:24 am
Post
by darat » Thu May 18, 2006 2:47 pm
psh EZ
Rabbi
Posts: 57 Joined: Sat Aug 12, 2006 4:02 am
Post
by Rabbi » Sun Aug 13, 2006 1:35 am
what motor did the Aero come with?
I ask because I'm in the process of fitting a Dio SR motor (AF18) to my 1980 Spree. The mounts are definately different... I think I will have to cut the Dio mount and weld the Spree mount onto it.
Did you ever get to finishing this project?
It would be sweet if you had some tips for me!
MySpree
Posts: 3291 Joined: Mon Jul 23, 1973 10:24 am
Post
by MySpree » Sun Aug 13, 2006 2:31 am
well the elite engine is diff then th aero, the bolts were diff sezes
Rabbi
Post
by Rabbi » Sun Aug 13, 2006 3:00 am
Are they both AF18E motors though?
darat
Post
by darat » Sun Aug 13, 2006 11:17 am
umm i didnt know that sprees were made in 1980 they were made from 84 to 87
hrnytrtlsgsxr
Posts: 719 Joined: Sat Dec 31, 2005 7:00 pm
Post
by hrnytrtlsgsxr » Sun Aug 13, 2006 2:28 pm
Rabbi wrote: Are they both AF18E motors though?
thye af18e motor is a dio motor not an aero motor
Rabbi
Post
by Rabbi » Sun Aug 13, 2006 4:15 pm
hrnytrtlsgsxr wrote: Rabbi wrote: Are they both AF18E motors though?
In New Zealand they are not called the same names thats why I'm asking.... what motor does the Aero have?
Rabbi
Post
by Rabbi » Sun Aug 13, 2006 4:33 pm
darat wrote: umm i didnt know that sprees were made in 1980 they were made from 84 to 87
mine is a 1980... its called a Nifty Fifty here in New Zealand. It looks just like a Spree, but it doesnt have those reflector things on the front wheel arch
darat
Post
by darat » Mon Aug 14, 2006 12:09 am
oh ok..
hrnytrtlsgsxr
Post
by hrnytrtlsgsxr » Mon Aug 14, 2006 1:16 am
Rabbi wrote: hrnytrtlsgsxr wrote: Rabbi wrote: Are they both AF18E motors though?
the aero should have a af05 motor which is the older version of the motor we call the dio now.Parts from the af05 motor can actually fit on a dio motor.
ryan.ott
Posts: 5 Joined: Sun Aug 06, 2006 9:49 pm
Post
by ryan.ott » Thu Aug 17, 2006 7:26 pm
Can you put dio parts (bore kits) on the af05
darat
Post
by darat » Fri Aug 18, 2006 12:32 pm
there the same as the se50 bore kit so yeah.. the highest that they have is a 65cc and that is a huge difference..
