EFI Kit?
wolf95
EFI Kit?
Post by wolf95 »
I'm looking at getting a '85 Spree in Wisconsin, and I stumbled across some EFI kits to replace the carb, I was wondering, does this actually have any performance enhancements over the stock carb? Or would I better off investing in something else? (ie Exhaust, Turbo).
This is the kit I'm looking at: http://www.ecotrons.com/files/SE-EFI-in ... Manual.pdf
zuphilius
Re: EFI Kit?
Post by zuphilius »
If you want speed, steer away from a Spree. Better off with an Elite or small motorcycle.
fastplastic
Re: EFI Kit?
Post by fastplastic »
AEM better watch out timmy and his soldering iron are going big time :bowrofl: If this kit even does work it not going to help the spree in anyway... spree needs longer legs and more power to even think about 40 :thumbwink:
Re: EFI Kit?
For the $300, you'd be better off swapping in a Dio engine.
Admin, Hondaspree.net
wolf95
Re: EFI Kit?
Post by wolf95 »
If I had my Class M, I would go with a Motorcycle, as it's only a few hundred more than what I'm paying for the Spree. DMV doesn't do checks after you register it do they?
abreen89
Re: EFI Kit?
Post by abreen89 »
wolf95 wrote:If I had my Class M, I would go with a Motorcycle, as it's only a few hundred more than what I'm paying for the Spree. DMV doesn't do checks after you register it do they?
nope register is as a 50cc do a motor swap no one needs to know..
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
Re: EFI Kit?
noiseguy wrote:For the $300, you'd be better off swapping in a Dio engine.
....+1.... :urban:
martynkim
Re: EFI Kit?
Post by martynkim »
Bad advice, in some states including Washington if you exceed 30 mph on a 50 cc you can be cited. The provision for the 50cc without endorsement is for 30mph or less. Check your States laws regarding this.
veedubh20
Re: EFI Kit?
Post by veedubh20 »
dmv cant switch moped into scooter! they cant do that!!!
dmv dont need to know !
wolf95
Re: EFI Kit?
Post by wolf95 »
Last night I was able to push it to 35, The only mod on it that I've seen so far is a different air filter.
fastplastic
Re: EFI Kit?
That's bad new filter means more air less fuel in some cases which means short life span of rings and piston
wolf95
Re: EFI Kit?
Post by wolf95 »
Correct me if I'm wrong, but doesn't that happen if your mixture is off? In which case wouldn't I just be able to tune the carb?
I don't have the stock airbox, as I just bought it and I just recieved the key, title and moped, nothing else.
zuphilius
Re: EFI Kit?
Post by zuphilius »
veedubh20 wrote:nope register is as a 50cc do a motor swap no one needs to know..
In Washington state in order to be a moped it has to have pedals. Anything else is a motorcycle.
wolf95
Re: EFI Kit?
Post by wolf95 »
DMV didn't check anything on my moped, I don't think that I'll have to worry about motor size.
