Need some sage advice and wisdom
Pete M
Post by Pete M »
My newly aquired, 2nd SB50p will not accecerate with the air box installed. Once removed it will jump to attention with a bog spot at 90%. It has a new top end, new intake gaskets, crank seals, the cleanest carb you have seen, the needle is in the middle position, new NGK spark plug, new fuel and vacuum lines, 135 psi compression, the bystarter tests good and seems to be working, the muffler was chemically cleaned, The plug will come out wet after a quick run around the block after it is warmed up. It appears to be running rich and the air cleaner just makes it worse. Without the filter in it, it bogs severely. I looked at the main jet and I can't tell if some one drilled it out. What say ye of 2 stroke Spree?
89 Elite E
Re: Need some sage advice and wisdom
Post by swimmingfree »
ajust the carb woood be my gusss ...
motomech
Post by motomech »
I suspect the muffler.
"Chemical cleaning" sounds like it should work, but I never have seem it to be effective.
odinxxix
Post by odinxxix »
sounds like you answered your own question. it runs rich. with air box off it gets the air it needs to run half way. i would get a replacement jet and put it in and readjust your carb. compare jets and see if the one in your carb is larger then a stock #68?
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
