I have my 84 spree that's been slightly modded.
Non Iowa exhaust,unmodded
domed piston from an 86
intake and reeds from and 86
intake has been portmatched for better flow
stock 84 cylinder head
exhaust port silghtly ported for a bit better flow
bigger 2.75 rear tire
bigger main jet
Spree starts and runs good, went from 23mph stock to 29-30 as indicated by the speedo. I am running a bit lean and went to the bigger jet I forget the number righ off hand but it's the bigger of the two offered for the spree. I need to know where I can find bigger jets to run in the stock carb. I do not want to put a bigger carb on this as I would like to retain the stock look as much as possible. Also if anyone knows a good jet size to run?
1984 honda spree jet help
1984 Honda Spree Iowa.
1986 Honda Spree Iowa.
Re: 1984 honda spree jet help
The jet is a #68 that I'm running as of right now and it's still lean.
- martynkim
You likely have an air leak.
#68 is the OEM jet for a non-Iowa model. If you have no air leaks or other issues, you can get larger jets from Honda.....bigger main jet....The jet is a #68 that I'm running as of right now and it's still lean....I need to know where I can find bigger jets to run in the stock carb
Check our our 'wiki link here for Honda P/N's
thanks for the info, I will check for an air leak first. If not then I will order some jets.
Well. checked for air leaks, non detected. sprayed carb cleaner while running around the cylinder base gasket,head gasket,intake,carb to intake, ect... no noticable change in the idle. did a copression check cold 125 psi. Wet compression test is 154 psi. have not done one warmed up. May be a possible air leak at the crank seals, but don't know an easy way to check that.
- patthesoundguy
Your air box lid could be leaking. Make sure the filter element is in good shape and properly oiled.
- patthesoundguy
I have the same setup on my 84 spree minus the domed piston. I have the 68 jet is perfect. If you had leaky crank seals you most likley would not have 125 psi. Unless you make changes to the carb or airbox you shouldn't be lean unless there is a leak.
