I have this weird knocking coming from the piston... What do you think it is, and how do I check it?
http://youtube.com/watch?v=lCkp0ztvk6g
Thanks,
Nick
Knock knock, who's there?
- 87spree70superbee
Black 85 Spree-SOLD
Red 87 Spree... Ended up buying the same one mentioned below.
I started riding my uncle's 87 Spree at the drag strip when I was 8...
It's easier to stop caring three years ago than it is to fix it in present time.
Re: Knock knock, who's there?
Anything from a loose heat shield to a bad connecting rod bearing. Check it by removing parts and looking what's underneath.
- 87spree70superbee
Done already.Pete M wrote:l would stop running it for starters.
Black 85 Spree-SOLD
- 87spree70superbee
Thank you. I was cleaning things on the scooter yesterday, and it seemed to start only after the engine had warmed up for a while. However I will check the heat shields and see if anything's loose.Wheelman-111 wrote:Greetings:
Black 85 Spree-SOLD
Good87spree70superbee wrote: Wed Oct 03, 2012 11:27 pmDone already.Pete M wrote:l would stop running it for starters.![]()
