Towing your scooter
Towing your scooter
Post by eliteguy50 »
So we've discussed trailers and hitch haulers and rooftops and... several mothods for hauling scoots but I've often wondered about these little receiver wheel chucks:
http://WWW.billybob1.com/insta-tow/insta_tow.html
Has anyone used something like this for a srooter? I am tempted to try it.
Re: Towing your scooter
Pros:
Easier to store than a hitch rack.
Does not interfere with the tailgate when the bike is removed.
Keeps the bike away from the truck so I don't loosen the wrong strap and cause scratches.
Could easily be used with a dirtbike.
Cons:
Scooter wheel wear.
Possible angle issues with the scooter? (Tanks spilling fluids...)
The wheel chuck may not fit the little spree wheels nor clear the low body panels.
Too close to the truck? (Road debris issues)
Pete M
Post by Pete M »
How fast do you think you can tow that back wheel with the belt floppin around in there?
89 Elite E
Pete M wrote:How fast do you think you can tow that back wheel with the belt floppin around in there?
The belt won't be an issue because the clutch won't be engaged. The rear wheel and the gears will face unnecessary wear. Either the bearings or tire would be the first to go IMO.
My plan is 55mph Max. Rising it to transport around/between town.
Pete M
Post by Pete M »
Why not just buy a cheap trailer?I would use a hitch mounted carrier with a ramp. I realize you wouldn't be able to put the tailgate down but it is easy to take off and put back on for the few times you would have to.
89 Elite E
Pete M wrote:Why not just buy a cheap trailer?I would use a hitch mounted carrier with a ramp. I realize you wouldn't be able to put the tailgate down but it is easy to take off and put back on for the few times you would have to.
I have a trailor and a hitch rack with ramp. This will be at least weekly use in the summer, maybe daily.
veedubh20
Post by veedubh20 »
veedubh20 wrote:http://www.gmimotorsports.com/2/Tilt-a- ... 10ACR.html
this is a good option..
That extendable ramp is slick. Have you had any problems with the 200# weight limit? A stock Ruckus or Zuma ('02-current) weighs over that.
paulpauly7
Post by paulpauly7 »
just ride it hahaha
For $399, the roll-on carrier that veedubh20 posted beats the first one by keeping the whole bike off the road surface.
Not a fan of spinning gears and such...I can't imagine either one being any easier than my trailer though.
More importantly, if a strap fails while bike is on my trailer,
it will likely not go bouncing and flipping down the road behind me.... :thumbwink:
I :heart: my trailer... :love:
Munstah666
Post by Munstah666 »
If both trailer kits needs to be hooked on trucks, whats the use use of the bed for? Just wondering ......:( ?
µùѵ£¼Òü«Òé╣Òâ╝ÒâæÒâ╝Òâ×Òâ│
Munstah666 wrote:If both trailer kits needs to be hooked on trucks, whats the use use of the bed for? Just wondering ......:( ?
Toolboxes and fuel tanks and air compressor ...
Also for use with SUV
veedubh20
Post by veedubh20 »
off course!
here the link!
http://www.tgifrv.com/2011/10/front-moped-carrier/
wiguy05
Post by wiguy05 »
veedubh20 wrote: off course!
here the link!
Possible citations:
Blocked headlamps.
Blocked front license plate.
Obstructed drivers view.
2006 Sachs Madass
- FTP 140cc Kit
2006 Xkeleton Trickster
- Lifan 90cc auto
Scooter/bike on front of vehicle is extreme....maybe with a boat/camper in tow and some additional lighting it works, but only just... :confused:
