86 Spree Industrial / Skelly Build...
MrChimpo
Post by MrChimpo »
I have an 86 Spree that I have stripped the Upper & Lower Guage / headlight plastics off of, Stripped the fender, and cut the Rear fairings. They're on my deck today and I am in the process of [60grit to 220grit wet to TSP/dawn soap bath] prepping for flat black rustoleum primer coat. I am planning on using DAP plastic filler for the holes in the paneling (since i deleted the blinkers FR/RR).
I need to know if anyone has had success swapping out the stock speedo for a universal / other Honda speedo? I want the old school stripped rat rod clean vintage look up top (Ive already deleted most of the excess wiring harness). I really want the build to turn out looking clean skelly.
Ill post some pictures of my progress on the bike this evening after I get some more of this plastic cleaned up.
1986 Honda Spree Partial Skelly w/ custom exhaust 8500miles
stucinthe80z
Re: 86 Spree Industrial / Skelly Build...
Post by stucinthe80z »
might try on from a honda express or rucus
curtis966
Post by curtis966 »
I would look at the trail tech vapor. If it will work on a Spree that I don't know.
