how do i check if a petcock is good
bigluelok
Post by bigluelok »
How do I go about checking if the petcock is still good?
CH80
Re: how do i check if a petcock is good
Post by swimmingfree »
with the motor not running just unplug the hose from the carb if gas come out then its notgood...
Determine which hose is VACUUM (runs from intake manifold to petcock.)
Remove FUEL hose from carburetor and place end into a jar or can to catch the gas.
If fuel runs freely from this hose, the petcock has failed.
If fuel does NOT run out, but starts running when you suck on the VACUUM hose, petcock is good.
Be cautious about putting any hose in your mouth unless you are SURE you have it correct.
breaze
Post by breaze »
motormike wrote:Be cautious about putting any hose in your mouth unless you are SURE you have it correct.
Good advice in many situations
'83 Aero NH80
'87 Elite SE50
'70 CT90
'72 CT90
'73 CT90
'74 CT90
You've been saving up for a long time...answer the question on the Gyro thread.
breaze
Post by breaze »
motormike wrote:You've been saving up for a long time...answer the question on the Gyro thread.
Done - almost forgot about that one. Sometimes life gets in the way...
'83 Aero NH80
'87 Elite SE50
'70 CT90
'72 CT90
'73 CT90
'74 CT90
