Need a Flywheel Puller for 2000 Honda Elite Sa50
sirtokalotadank
Does any1 happen to have a spare flywheel puller for 94-01 honda elite sa50? or does any1 know of any way to remove the flywheel without puller or know how to make one myself if not....IM IN DESPRITE NEED BECUZ MY CRANK BEARINGS NEED CHANGED AND I CAN GET TO EM!!
Re: Need a Flywheel Puller for 2000 Honda Elite Sa50
I just use this:
http://www.harborfreight.com/46-piece-b ... 37824.html
Only $13 at HF right now (before coupons).
1986 Spree w/ '87 SE50 motor
I used that exact set to split the cases prepping for Flash 5 in Builds.
However as a flywheel puller it's a bit wobbly and tricky to set up. Great Risk of threading the M6 bolts too far into the flywheel and buggering up the Stator. Rocky Mountain Sports sells the 24mm R-Hand thread puller for Honda and many others; Screw on, Couple of twists on the bolt and POP. With the steering wheel puller: Proceed with caution.
sirtokalotadank
Got it! With Steering Wheel Puller!! Thanks!!!
