honda elite sb50p doesnt idle/run right
azndude3141
Post by azndude3141 »
ok, it has a brand new coil, sparkplug, and fresh gas (somewhat new oil). 6months ago, it ran and idled perfectly. after not starting it for a while, it didnt want to even start at all without ether. so i cleaned the carb and found the main jet was clogged. i put it back together and it started easily. however, it wont run continuously and it has a very inconsistent idle(it randomly goes up and down in rpm). i cleaned every part on the carb possible. PLEASE HELP!!! its making me very frustrated and i tried every combination of the air mixture screw with no luck. i have a video of the problem and i will upload it shortly
deuce217
Re: honda elite sb50p doesnt idle/run right
Post by deuce217 »
Drain that old gas out, fill her back up with new. Do you know how to adjust your a/f screw? What did you gap your spark plug to? Look for the honda manual on this site I bet you can follow the trouble shooting steps and find the problem quick.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
Pete M
Post by Pete M »
89 Elite E
Pete M
Post by Pete M »
You have an intake leak at the spacer between the carb and the manifold. Repair the threads on the rear bolt and replace the 2 orings on the spacer and carb.
89 Elite E
azndude3141
Pete M wrote:You have an intake leak at the spacer between the carb and the manifold. Repair the threads on the rear bolt and replace the 2 orings on the spacer and carb.
how do i repair the threads on those? it feels like they are holding pretty tight, and the o rings are still very rubbery, they dont feel like they are rotted. can i spray starting fluid around the carb to test if it is an air leak?
Post by swimmingfree »
do you have the o ring on the by starter??? it looks off set...
you shood no that the Manuel is a starting point not the end point... start the motor let it worm up then a just the air till the motors rpm goes up then turn down the idle till the tire is just rolling ...
Pete M
Post by Pete M »
I can see in your video that the rear bolt for the carb is not tight. Those orings are 23 years old so I doubt they are sealing anything. I have 2 sb50p's and an intake leak is the most common issue for it not running correctly aside from a carb that is not clean enough. The pilot port in the carb is the another issue to readdress.
89 Elite E
