Honda spree engine destroyed.
mauricio328
Post by mauricio328 »
I was riding my 86 honda spree and i heard a clicking sound in the engine and then it died. my friend took it apart and said that something in the engine broke scratching the cylinder and piston. i want to know how this would happen. did it overheat? if i fix it how can i ensure it will not happen again.
azndude3141
Re: Honda spree engine destroyed.
Post by azndude3141 »
did your oil pump work? maybe you ran it without oil getting to the engine. that would cause it to overheat, and then break
devenex
Post by devenex »
Any idea what scratched the cylinder? piece of piston ring? The dreaded loose circlip?
Hard to advise on odds of a repeat with so little info.
1986 Spree w/ '87 SE50 motor
mauricio328
I believe the rings just broke and pieces scratched the cylinder and piston.
paulpauly7
Post by paulpauly7 »
dude swap in a dio!
Pete M
Post by Pete M »
Could have been a piece of carbon from the head or exhaust port. Do you still have oil in the oil tank?
89 Elite E
Really would need to see pics of the bore and piston to tell. Either way you'll need a new piston and rings, and a cylinder boring.
You should at that time decarbonize the bore and check oil pump operation as part of the rebuild.
