1994 Honda elite SR won't start.
birdman3131
Post by birdman3131 »
Ok I have a 1994 honda elite sr that will not start. Some of the wireing has been modified and I am not sure if it is the wireing or a carb issue. What would be the bare basic wires I need to have hooked up to get it to start? It does have spark and the spark plug is new. No battery but the kick start works to turn the motor and cause spark.
And if it is the carb what do I need to keep an eye out for?
I can get pictures iff needed
The scooter did run right before I got it but died and would never start again.
Re: 1994 Honda elite SR won't start.
Post by swimmingfree »
birdman3131
So I just attach the tester and start pumping the kick starter for 30-60 seconds? Asking cause I don't have a battery.
paulpauly7
Post by paulpauly7 »
with the throtttle wide open
Throttle open wide, or just remove the carb. Reeds must remain in place.
Kicking will cause the pressure gauge indicator to rise a little less with each kick. Note where it stops rising altogether and that's your compression PSI.
birdman3131
well s***. im only getting 35psi. also found that the piston had apperently hit the spark plug. how much is a new piston and where should i get one?
sc94elite
Post by sc94elite »
greetings
Powersportsplus.com has the stock piston if that's what you want. or you can go bbk you should check the cylinder for scores and replace the rings while you're at it. Find out why the plug hit the piston. Maybe the wrong plug was used?
birdman3131
Well I am back. I put in the proper sparkplug and it started right up and I have been running it. Give me a couple weeks and I may look into a few performance upgrades.
