Petcock
Petcock
Took my petcock off today to check it and the filter and found a small hole in the filter. My question is do the non honda petcocks which come with the filter included work properly? I have had a look at them and there does not seem to be a vacum pipe on them like the genuine honda ones? I can probably get a new filter but they are about £25 or $35 fo the filter alone and if the other petcocks are ok I may as well swop the whole lot.
Thanks Danny.
Thanks Danny.
Re: Petcock
Danny has a 1985 Honda Vision....
Re: Petcock
Thanks motormike. Lol I always forget that bit. Sorry all.
Petcock
I've got a nice working petcock and filter in good condition if your interested. Off a 87 aero 50.
Re: Petcock
Hi Mate,
Thanks for the offer but I'm in the UK and the postage would be more than what I can get one for here. However your picture is very useful. On mine there is a thin metal pipe which the filter slides on to and then a clip and a little air filter goes on the top. From your picture there isn't one? Do I take it from this that that bit is not required?
Cheers
Danny
Cheers
Danny
Petcock
Hmm not sure on that one. This is the only petcock I've pulled I guess. Never been inside my aeros tank.
Manual pic but I can't tell.
Petcock
Little bigger
Re: Petcock
http://www.cmsnl.com/honda-nb50m-aero-5 ... F++11.html
Have a look at the petcock on the link above. It exactly the same as the schematic pic you posted except you can see the pipe I describe. However if the one in your pic works which it will it will explain why all the new ones I can buy dont have the pipe.
- PorterGuy85
Re: Petcock
Wouldn't still happen to have this do you? Will it fit my '85 nb50m? I keep getting ones that have the threads too large. I think they're for sprees. Thankscurtis966 wrote:I've got a nice working petcock and filter in good condition if your interested. Off a 87 aero 50.
Re: Petcock
viewtopic.php?f=3&t=25144&start=30
Petcock threads are 14 x 100mm
I once had an '85 Aero with a bad petcock... it is not typical as you know. I gave up and bypassed it - just me - worked out fine off the float in the carb bowl.
Best Regards.
Best Regards.
'86 Spree - Gone
'86 Spree - Gone
'85 Aero 50 - Gone
'94 Elite SR - Gone
'96 Elite SR - Gone
'01 Elite S
'85 Gyro - Its Alive
'86 Spree - Gone
'86 Spree - Gone
'85 Aero 50 - Gone
'94 Elite SR - Gone
'96 Elite SR - Gone
'01 Elite S
- PorterGuy85
Re: Petcock
Hmm, i'll have to research how this is done. Heard about the 11mm on/off valve
- PorterGuy85
Re: Petcock
Yup, im going with the on/off/reserve style no vacuum line. M14 equivalent to 16950-187-671
Thanks! !
Thanks! !
Re: Petcock
For reasons known only to Honda-san, the petcock sizes got bigger in 1986-later. An'87 petcock won't fit an '85 tank..
