Heres my video, someone please help...
1987 SE50 with Malossi kit and head, CT intake, 21mm OKO, leo vince pipe, new rings, new base gasket, carb cleaned three times, new fuel filter. choke is off in this video.
http://www.youtube.com/watch?v=pRDuEDNc ... e=youtu.be
- swimmingfree
Re: Heres my video, someone please help...
is your pet * working right ??
adjust the carb
adjust the carb
Checked petcock, works great. Screws are set to stock on Carb. Adjusted jets from leanest ones I own to richest and every combination in between. Took a whole day.
And compression is 120psi
- swimmingfree
what jet do you have in it now ????
were the needle set at ????
Needle is in the middle. Pilot is 42, main is 105. This was my most successful Carb setting on my last engine before I ruined an oil seal and swapped this engine in.
- swimmingfree
pull the spark plug and see how it looks wet dry and color as well and what is the gap on the plug???
Spark plug is brand new gap is whatever it comes with. Plug was not wet when I pulled it to check compression. BPR7S is what I've always used.
- swimmingfree
if the gap is to big it will have a hard timer running the same thing happen if its to small...never trust what it come with ..
- paulpauly7
sounds like i big air leak does it run better with the choke on or off
Off, by a very small margin.
There are two occasions(in the vid) that the engine gives out a couple of "pfftts" when it dies.
Those sound very suspicious....like an exhaust leak or vacuum leak.
The intake was resealed when I reinstalled it. Think it could be the case gasket or oil seals?
JustynCRX wrote:The intake was resealed when I reinstalled it. Think it could be the case gasket or oil seals?
You may be right. I would be looking at those two as possible.
- patthesoundguy
Is the spark plug torqued properly. It also sounds like its lean all around.
