My AF18
My AF18
Sup everyone .. name is raindrop and im trying to build a bad * scoot
heres what i got so far .. 2004 kymco zx which is a dio af18 engine
a 48mm bbk .. 24mm oko carb .. high performance varitior .. and dio v8 exhaust
what im asking you no it all's is what else should i get ? i wanna go like 50-55 cruise
but 0-55 i want fast .. like sprint fast .. please drop some info guys ..
is a 120 jet to big ? i have other jets .. ohh and oil has been blocked off
thanks ... your scoot lover raindrop
2004 Kymco ZX 72cc..
1972 Honda Mt250 Elisnore..
- Downsouthdio
Re: My AF18
Does your zx have aftermarket gears? What speeds are you reaching now?
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
Re: My AF18
no just stock gears .. like 50 mph but not completely broke in yet ..
live in mi so its getting cold to ride .. started build in oct
but its gonna be 47 degrees fri so zoom zoom .. more testing
- Downsouthdio
Re: My AF18
I reccomend aftermarket gears.. It will keep your rpms lower so you arent constantly straining the engine, and you will gain more on the top end..
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
Re: My AF18
Where in MI?
- tazland001
Re: My AF18
Get some gears raindrop. They are one of the most important part of any upgrade.
Taz
Taz
Re: My AF18
Quoth DownSouthDio:
Quoth DownSouthDio:
This suggests you don't understand the concept of Continuously Variable Transmission, South. Steady-state cruising RPM will NOT be affected by the mechanical gears, but only by alteration at the Belt-Drive.I reccomend aftermarket gears. It will keep your rpms lower...
The engine spins up at whatever RPM the belt-drive dictates, until the belt "tops out". By that time, a stock engine pretty much runs out of juice, (I can't believe the potty-mouth police deleted pee oh oh pee!) even with stock gears. High RPM operation doesn't "strain" the engine as much as lugging, when both lubrication and fan-forced air are scarcer. If lubrication and cooling are adequate, a two-stroke engine self-limits RPM as dictated by intake, porting and exhaust. Running wide-open all day is possible, 'til the fuel tank runs out... so you arent constantly straining the engine,...
Once again, a kernel of truth but the statement misses the point. If the engine has the ponies to push faster than the stock gearing+belt "overdrive" allow, then yes taller gears will increase speed. If not, Nope, unless you find a nice downhill....and you will gain more on the top end.
- Downsouthdio
Re: My AF18
He has a bbk.. Go ahead and run your zx with the stock gearing..
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
- kingkamehameha
Re: My AF18
I was waiting for that. I kept my mouth shut in lew of the trollers on here. You pretty much nailed it. Im glad to know that there are people out there like yourself wheeldude who know the physics quite well. Gearing is misconcieved wrong by most. A cvt trans is tricky to wrap your mind around at firstWheelman-111 wrote:Greetings:
Quoth DownSouthDio:This suggests you don't understand the concept of Continuously Variable Transmission, South. Steady-state cruising RPM will NOT be affected by the mechanical gears, but only by alteration at the Belt-Drive.I reccomend aftermarket gears. It will keep your rpms lower...The engine spins up at whatever RPM the belt-drive dictates, until the belt "tops out". By that time, a stock engine pretty much runs out of juice, (I can't believe the potty-mouth police deleted pee oh oh pee!) even with stock gears. High RPM operation doesn't "strain" the engine as much as lugging, when both lubrication and fan-forced air are scarcer. If lubrication and cooling are adequate, a two-stroke engine self-limits RPM as dictated by intake, porting and exhaust. Running wide-open all day is possible, 'til the fuel tank runs out... so you arent constantly straining the engine,...Once again, a kernel of truth but the statement misses the point. If the engine has the ponies to push faster than the stock gearing+belt "overdrive" allow, then yes taller gears will increase speed. If not, Nope, unless you find a nice downhill....and you will gain more on the top end.
Re: My AF18
It took me less time than some. I grew up with Primitive Snowmobiles - like 1969-1973 Skiroules - and always marveled at how they seemed to find the right "gear" for every speed, incline and snow condition. Honda-san improved on those however, taking the clutch function away from the variator and isolating it within the driven pulley. You don't ever want to smell a drive belt melting from getting stuck if you can help it...
Re: My AF18
ok so new gears .. what about clutch and springs ?
and i live in good old Roseville mi ..
like i said 48mm bbk and 24mm oko that * gas
Re: My AF18
So what gears do i buy? and do i need to change crank.?
Re: My AF18
The stock Honda crank is as durable as any, better than most. Leave it unless you have reason to believe it's worn or damaged.
8.44 gears for the setup you describe will give you the best compromise in acceleration, still able to reach 55+ if tuning is well done.
Re: My AF18
So do i search for 8.44 gears zx50 ? does taz have this for sale ..
