Hm, will these work for an 94+ sa50?
http://japan.webike.net/products/21007916.html
"Hirochi-Shop" wheels
Re: "Hirochi-Shop" wheels
well, price was so cheap that I ended up ordering the front. saw somewhere on here that the af16/18 block should be the same for rear wheel, figured it should be the same for the front. Guess we shall see!
Excited because my front rim is bent and this cost me $24.xx shipped !
Let me know how it fits quite a steal for sure. Would definitely be getting a set or 2 for the aero.
- Downsouthdio
The af18 dio is disk front rear i think would work
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
Not sure that this is a disk front, actually. This is the photo of the front rim.
Here's an SA50 front for comparison
According to a Russian site i just found
"ðí 1988 ð│ð¥ð┤ð░ ð┐ð¥ 1992 ð▓Ðïð┐ÐâÐüð║ð░ð╗ð░ÐüÐî Honda Dio AF 18 ÔÇô ð▒ð░ðÀð¥ð▓ð░ÐÅ ð╝ð¥ð┤ðÁð╗Ðî Ðü ð┤ð▓ð©ð│ð░ÐéðÁð╗ðÁð╝ AF18E ð© ð▒ð░ÐÇð░ð▒ð░ð¢ð¢Ðïð╝ð© Ðéð¥ÐÇð╝ð¥ðÀð░ð╝ð©. ðƒð░ÐÇÐÇð░ð╗ðÁð╗Ðîð¢ð¥ Ðü AF 18 , Ðü 1990 ð┐ð¥ 1992 ð▓Ðïð┐ÐâÐüð║ð░ð╗ð░ÐüÐî Honda Dio AF 25 ð©ð╗ð© Honda Dio SR ð¥Ðéð╗ð©Ðçð░ð▓Ðêð©ð╣ÐüÐÅ ð¥Ðé AF 18 ð│ð©ð┤ÐÇð░ð▓ð╗ð©ÐçðÁÐüð║ð©ð╝ ð┤ð©Ðüð║ð¥ð▓Ðïð╝ Ðéð¥ÐÇð╝ð¥ðÀð¥ð╝ ð¢ð░ ð┐ðÁÐÇðÁð┤ð¢ðÁð╝ ð║ð¥ð╗ðÁÐüðÁ."
From 1988-1992 the Dio AF18 was the base model AF18e with drum brakes. The Honda also made a AF18 from 1990-1992 with disc brake up front, Honda Dio AF25/Dio SR.
http://www.honda-dio-af.ru/af18251988-1992/
Doing a bit more research for those interested:
It seems that the SK50m (Dio) shares the same part number for the brake pads as the 94+ SA50..
As long as the drum brake panel is the same fit, which it looks to be, I think this will work just fine.
Hope web bike ships relatively quickly and I will know soon!
