Thinking about opening up my Spree engine...
87spree70superbee
Post by 87spree70superbee »
Okay, so I am thinking that over the next few months that I'd want to pull my engine out of my Spree and go through it. Are there any special tools I'd need to split the engine open? I want to take it down, clean it out, and re-assemble it.
Thanks,
Nick
Black 85 Spree-SOLD
Red 87 Spree... Ended up buying the same one mentioned below.
I started riding my uncle's 87 Spree at the drag strip when I was 8...
It's easier to stop caring three years ago than it is to fix it in present time.
kingkamehameha
Re: Thinking about opening up my Spree engine...
Post by kingkamehameha »
You need a flywheel puller and a crank installation tool and a pair of bearing pullers. Why go thru the time to do it tho its just a terd spree engine
87spree70superbee
graphite9 wrote:You want to take it apart to clean it? Leave it. If it aint broke don't fix it.
It was sitting for 20 years in some dude's garage, un-winterized. It runs iffy. I've cleaned everything multiple times and it's not the best it can be. Plus, when I get bored I tend to like to take things apart. :-P
Black 85 Spree-SOLD
87spree70superbee
kingkamehameha wrote:You need a flywheel puller and a crank installation tool and a pair of bearing pullers. Why go thru the time to do it tho its just a terd spree engine
Thanks. I bought the Spree as a learning project, I like engines, I like taking things apart... Here we are. I don't want to swap in an engine because A, Dio's aren't terribly common in my area, and B, I really don't want to be going 50+ on a tiny little spree... For that, I'll just borrow my dad's Kymco. :-D
Black 85 Spree-SOLD
abreen89
Post by abreen89 »
THIS FORUM IS CALLED HONDASPREE.NET PEOPLE LIKE THEM THE WAY THEY ARE GO TO A DIFFERENT FORUM TO TRASH TALK THEM>> :hi:
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
kingkamehameha
Your just mad your stuck at 40 with all your bikes
kingkamehameha
I trash talk anyone who insist on wasting time on a slow outdated engine
abreen89
Post by abreen89 »
if i wanted to go faster i wouldnt own A SCOOTER.... On the mainland we have things called cars.
abreen89
Post by abreen89 »
kingkamehameha wrote:I trash talk anyone who insist on wasting time on a slow outdated engine
hmm the engine that the WHOLE WEBSITE IS BASED ON!!
kingkamehameha
Its based on spree and elite 50 dont tell me what its based on. The only benifit you will get from a bottom rebuild is new bearings and seals. Just saying why go thru that kinda work its just plain old dangerous to be going 25-30 holding up traffick like that. 45-50 on a spree isnt bad its actually pretty smooth riding
paulpauly7
Post by paulpauly7 »
50mph on a spree = good times all round :-)
87spree70superbee
OKAY BACK TO TOPIC NOW
Black 85 Spree-SOLD
patthesoundguy
Post by patthesoundguy »
I'd get a new piston and rings from taz and get a new bearing for the piston pin. Get new crank bearings and seals so when you get the thing torn down you will have new parts to put in. There isn't much other than worn out parts to make a spree run "iffy". The bottom end isn't really the part that needs cleaning up it is the carb and top end that needs the attention. You will likely find that the bore needs deglazing and the exhaust port will need the carbon cleaned out of it. The head will need to cleaned up. I say tear it all down if you want because you will have a whole new machine when you get it all back together with new seals and bearings.
Post by swimmingfree »
if your going to crack the case you shood do some port work as well ...
patthesoundguy
swimmingfree wrote:if your going to crack the case you shood do some port work as well ...
Good idea swimmingfree its a perfect time to port that thing.
