Got me a Dio 3. At present doing rebuild. Overhaul motor rewire will do repaint of plastic .
Replace stator coil and pulser. Got parts from a local store.
http://s1110.beta.photobucket.com/user/ ... 5.jpg.html
Dio 3 build
Re: Dio 3 build
my dio3 is painted red. but have idling problem, my mechanic says it is the crankshaft out of alignment.
uk-visionsa50
Re: Dio 3 build
if its an idling problem id be looking at the carb, have you tried adjusting the idle screw?
- tazland001
Re: Dio 3 build
sounds like the pilot jet bro not the crank.
Taz
Taz
