What octance?
clsmooth
What octance?
Post by clsmooth »
I was told by the previous owner that these scooter will only run on cheap stuff (around here that's 87 octance). Anything higher will wreck or blow the engine apparently.
Thing is, the previous owner was some pothead kid. So I'm wondering what grade octane you guys runs and with what results?
"All the money in the world doesn't buy you good technique."
berreta22
Post by berreta22 »
87 octane is fine. The engine will only run hotter with higher octane and with the fuel at 3 bucks a gal or so the extra money aint worth it. Just run the cheap crap.
1987 Spree 4400 miles 32 mph stock with my 285lb ***
bitteraspects
Post by bitteraspects »
your octane rating isnt going to make that much of a difference in preformance. only price. i run 92, but thats just out of habbit
-aL-
Post by -aL- »
when you only have to fill a one gallon tank, theres no reason to not run premo gas
Ridin' Dirty on one of my 1989 Honda Elite E's
bitteraspects
exactly
berreta22
Post by berreta22 »
one gallon? lol i wish!! I mean mine holds like a half gallon or something...its been a while since i rode since im rebulidin the engine.
myhonda
Post by myhonda »
i dont know. i run the good gas in my peds.
clsmooth
Post by clsmooth »
Sounds like the choice of octane comes down to personal preferance then... ?
Pretty much. Try both and see which you like better.
Higher octane runs colder, BTW. That actually slightly degrades performance on low compression engines. My thought is that I'd rather the engine ran colder on an air cooled plant.
myhonda
Post by myhonda »
well me and a freind of mine experimented with the gas thing and octain long ago. the cheap gas in his car ( his car had a warped rod in it) when it got to 80 the car started ticking from the rod and was at 6 1\2 rpm's. the good gas we got to 90 and moter just started ticking while running at 6 1/2 rpm our theary the moter doesent have to work as hard with the good gas as it does with the cheap gas
Higher octane protects against predetonation, which is probably what you heard.
It's really engine dependent. Just run a tank or two and make up your own mind.
myhonda
Post by myhonda »
no it definetly had a warped rod in there. it was a loud tik for a car to make
Spreewell
Post by Spreewell »
I run 108 high perf and smokenutz. Klotz synthetic with da high perf with get ya 35 on the dream meter...even if your a fatty lard azz.
myhonda
Post by myhonda »
where u get 108 octaine????????? i can only get 97 around here
clsmooth
Post by clsmooth »
The most I can get at the pump in my neck of the woods is 94.
