24mm oko
Raindrop
Re: 24mm oko
Post by Raindrop »
Ok ill play with air /fuel screw tomorrow.
What size jet u run in your 48mm bbk?
I still think i need a 120 at least. ? Idk i could be wrong.
And crazy thing it ran better with gas p i ssing out every where. lol
d*** carbs :x
2004 Kymco ZX 72cc..
1972 Honda Mt250 Elisnore..
abreen89
24mm oko
Post by abreen89 »
Start with the biggest jet u have then work your way Down or else risk running to lean.
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
Raindrop
Re: 24mm oko
Post by Raindrop »
Ok. but i still would like to know what jet size you use.
Cause i have the 48mm bbk
abreen89
Re: 24mm oko
Post by abreen89 »
I dont remember what jet i have in their but im running a 19mm pb carb with a bystarter so your 24 oko is going to be different its a much bigger carb. But i do believe im running a 120 ish or smaller
Raindrop
Re: 24mm oko
Post by Raindrop »
Got the carb working right now. but i think im going to put my 120 in
115 seem to be to lean. plug a lil dry and greyish .. Lol
What oil ratio should i run to.?
abreen89
Re: 24mm oko
Post by abreen89 »
Raindrop wrote:Got the carb working right now. but i think im going to put my 120 in
are you doing plug chops? too see if its lean or not?
Re: 24mm oko
What size is the pilot jet?
Raindrop
Re: 24mm oko
Post by Raindrop »
48 i think stock pilot. Its one came with carb. It just came with main jets 108 - 130 to play with.
Raindrop
Re: 24mm oko
Post by Raindrop »
dude this carb sucks * i cant get this s*** tunned right i need a 2 stroke guy in michigan .. getting * !
bakaracer
Re: 24mm oko
Post by bakaracer »
Post a pic of the carb you have
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
Raindrop
Re: 24mm oko
Post by Raindrop »
SuprasNsprees
Re: 24mm oko
Post by SuprasNsprees »
I've got that carb on a 64cc Polini SpreeDio. 4-petal CT, V8 pipe, and taz gears. Went 61mph on a 105 main but she was HOT. Runs cool with a 115 at 58 mph
'80 Puch Magnum MKII
'78 PA50 Hobbit
bakaracer
Re: 24mm oko
Post by bakaracer »
Do you have the hose for the power jet connected? Its that hose that goes from the bowl to the top of the mouth if the carb.
91 yamaha tzr 250r
