NQ50 Spree Engine Build
Tyler VR
Re: NQ50 Spree Engine Build
Post by Tyler VR »
patthesoundguy wrote:That is one nice looking jug dude :-) that will be a joy to work on. I'm jealous I want a nice cylinder like that to port ;-) that won't take much to make it a winner :-)
Thanks, working on clean parts is nice but it just takes more time.
Tyler VR
Post by Tyler VR »
Tyler VR
Post by Tyler VR »
Just got another spree engine my brother donated to me, good to have spares.
Tyler VR
Post by Tyler VR »
Honed the cylinder.
patthesoundguy
Post by patthesoundguy »
That looks perfect :-) that makes a big difference in performance.
Tyler VR
Post by Tyler VR »
Cleaned up the piston and head, then did a quick polish job.
patthesoundguy
Looks sweet, the carbon won't want to stick now ;-)
kingkamehameha
Post by kingkamehameha »
Boost port looks ruined
Tyler VR
Post by Tyler VR »
Got gaskets and rings, I have a 3 day weekend off work so I should have the time to put it back together.
patthesoundguy
Can't wait to see how it works when you reassemble it. Its exciting :-)
Soak the base gasket and the reed block/intake gaskets well with 2 stroke oil. Then you will be able to pull stuff apart and play with it and not have to replace the gaskets every time.
Tyler VR
Post by Tyler VR »
All the parts cleaned up and ready to be put together.
Tyler VR
Post by Tyler VR »
Tyler VR
Post by Tyler VR »
The crank is ready to go, I put it in the freezer.
kingkamehameha
First of all the crank bearings need to be removed from the crank and new ones put into the case first! It wont go in straight with the bearings on the crank! Secondly the crank case and intake area needs to be rough enough for fuel to atomize. Its not supposed to be polished like that.
Tyler VR
Post by Tyler VR »
Heating up the cases with my oven and heat gun.
