Kymco zx-50 question
Raindrop
Re: Kymco zx-50 question
Post by Raindrop »
2004 Kymco ZX 72cc..
1972 Honda Mt250 Elisnore..
Downsouthdio
Post by Downsouthdio »
Nah wont work. Af05e primaries will work from what i hear.
Honda super dio
Corsa
26mm
Sparrow
Tate
Post by Tate »
Yeah stock ZX50 gears are already pretty tall.
LMH
Post by LMH »
Only 10.5:1, less than the af05es 10:1 ratio. Af16 is 11:1. GY6/139qmb final gear is a direct swap, and the primary shaft also. The counter is not.
LoveMyHonda wrote:Only 10.5:1, less than the af05es 10:1 ratio. Af16 is 11:1. GY6/139qmb final gear is a direct swap, and the primary shaft also. The counter is not.
Stock ratio on a af16 is 12.1:1
The kymco also has a 12" tire, so that will make the overall ratio even higher.
LMH
Post by LMH »
oops my vague recollection thought they were 11:1, so would that mean the af05e is the 11:1? The zx50 is in between the two.
JJ Joseph
Post by JJ Joseph »
The Kymco is a Dio engine on a long case (12" wheel). It's geared plenty fast right out of the box with the 12" wheel. No need to do anything.
