Batteries are always a problem .
Here is a dumb tip .
On some batteries the screw will not reach the battery bolt terminal once the connector is on .
Here is what I do too solve the problem .
Take a small piece of foam cut it a little larger than the terminal hole .
stick it and the nut / lug into the terminal hole / The foam will hold the nut in place .
No more messing around trying to catch the threads in the nut or having them fall out if you tilt the battery .
What could be simpler than this ?
Battery Tip / short bolts (66six)
- all you need sizzor / foam / nuts & bolts and a battery .
- 100_3542.jpg (47.02 KiB) Viewed 3269 times
- 100_3548.jpg (40.62 KiB) Viewed 3269 times
- The foam holding the nut in place .
- 100_3549.jpg (48.22 KiB) Viewed 3269 times
Re: Battery Tip / short bolts (66six)
Nifty idea.
- patthesoundguy
Brilliant completely brilliant thanks for sharing
My idea of using shrink tube or a drinking straw may not be simpler, but less likely to attract and hold moisture....besides, I use all my foam rubber to stuff sock-monkeys....66SIX wrote:What could be simpler than this ?
- sockmonkey.jpg (13.94 KiB) Viewed 3227 times
motormike wrote:My idea of using shrink tube or a drinking straw may not be simpler, but less likely to attract and hold moisture....besides, I use all my foam rubber to stuff sock-monkeys....66SIX wrote:What could be simpler than this ?![]()
Drinking straws do hold moisture thats what they are made to do ...
The shrink tube would shrink in Vegas summers 125 degrees.
Straws should be used to consume Myers & coke or foo foo drinks in Mexico .
You say you can't find foam it's everywhere you just need to look ...
- I am using a straw in Mexico to retain moisture . Not to hold my nuts in a battery .
- IMG_1341.jpg (59.17 KiB) Viewed 3225 times
- Mike this is what straws are used for / retaining moisture .
- 100_5800.jpg (49.59 KiB) Viewed 3225 times
- I think I found a good source for finding foam
- 100_1184.jpg (42.48 KiB) Viewed 3225 times
Johnniespeed
I'm going on a foam source finding mission.
Elite 150 64 mph for sale.
Elite 250 77 mph. for sale.
- patthesoundguy
Your local dollar store will probably have foam. Sometimes they have foam floor tiles on the kids toy section, or in the craft section
