Tires Not sitting properly???
WeeMan
Post by WeeMan »
I have changed both front and rear tires. I have fitted 90/90 by 10 Michelin S1's. No problem fitting them but for what ever reason they are not fitting central. Am I doing somthing wrong when inflating them?
Thanks
Danny
I have a uk 1985 vision if it makes a difference.
Duosport
Re: Tires Not sitting properly???
Post by Duosport »
It happens. Your tire is not sitting proper on the rim. Try letting the air out and hit the side of the tire with a rubber mallet while you inflate the tire. If you work at it you can get it to set properly. Even putting the tires on the scooter and riding it can set them. Good luck keep working at it.
vette76
Post by vette76 »
what are you airing them up to? i aired mine up to 40 before they popped on the bead. i wouldnt go higher then 50ish though.
87' spree (SOLD
12' wrx
bakaracer
Post by bakaracer »
use soapy water or wd40 before you inflate. the edge of the tire is hanging up on the lip where it needs to seat
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
WeeMan
Post by WeeMan »
Got the tyre back off. Can I ask when I re fit a new tube should I bolt up the valve tight before I inflate or should I leave it loose?
Thanks
Danny
Duke
Post by Duke »
Leave the valve stem loose until you inflate, I have often had the thick part of the tube at the stem area wedge under the bead and cause all kinds of headaches. Thread the stem nut on the first part of the stem and push it into the rim to ensure that its clear of the bead, I use Simple Green mixed with water as a temporary lube to help the bead seating!
87 Elite 50
99 Aprilia SR50 Carb polini
1973 Suzuki TS185 smoker!
2002 KTM Duke
WeeMan
Post by WeeMan »
Tried all sorts but still cant get it to sit right. Got it at 50psi and still hasn't done it. How high can I go with presures before I risk injury?
vette76
Post by vette76 »
i get nervous beyond 50 with steel belted tires. i wouldnt do it with a scoot tire. i think you really just need to lube it a lot more. use straight dish soap. i have never had this issue really with a scoot tire.
87' spree (SOLD
12' wrx
