drag style spree???
diosoljah
drag style spree???
Post by diosoljah »
atarp
berreta22
Post by berreta22 »
in this same forum look under "you said it couldnt be done" its like 3 lines down from where you posted this topic. does this answer your question?
1987 Spree 4400 miles 32 mph stock with my 285lb ***
diosoljah
Post by diosoljah »
atarp
hrnytrtlsgsxr
Post by hrnytrtlsgsxr »
diosoljah wrote:well, thats not really what I had in mind, that spree was strectched from the middle what I meant is perhaps a stretch on the motor mount, kinda like the pic belowImage
cycle imports had one that was stretched with the motor mount.
maddog
Post by maddog »
Thats what they do in Japan also with panels & exhausts, go to quik fix cycles & ask to see a catalogue.
darat
Post by darat »
i think that someone allready tryed that.
diosoljah
Post by diosoljah »
atarp
hrnytrtlsgsxr
i noticed that you compressed the front springs of forks to lower the front.Did you groove the leg shafts to bolt it through at the lower point? Looks like you shortened the stem too. which you would have to do.
hrnytrtlsgsxr
what kind of headset is that too? JAPAN? Cause the way the bolt is set up on the neck is for a japan headset.
Nice start... keep us posted.
MySpree
Post by MySpree »
alredy done by mopedmam, that how i got the dio spree, its not a dio spree no more, its an aero spree. dragster
darat
Post by darat »
yeah but it never ran.
MySpree
Post by MySpree »
it will now, all i have to do is start it up and itle run. o and get an ignition
diosoljah
Post by diosoljah »
atarp
diosoljah
Post by diosoljah »
atarp
