idle adjustment problem
bigbaer
Post by bigbaer »
I've had some previous problems carb related (http://www.hondaspree.net/phpBB/viewtopic.php?t=2424), and ended up taking "noiseguy"'s advice and getting a rebuilt carb from Greg. After getting it hooked up, she fired right up. The problem is, with the air screw ALL the way in, and the idle screw about 3/4 of a turn out, I'm still idling a little high. I'm assuming it's a vacuum leak. Where can I have a vacuum leak from? I've checked the intake, vacuum line going to petcock, the o-ring on the spacer, and the air cleaner area, with no apparent way of air getting in. Am I wrong, and it's not a vacuum leak, and if that's the case, what's else could be going on?
'86 Spree, handed down from grandfather-in-law
berreta22
Post by berreta22 »
There is only one line as far as vacuum related..its the line from the intake but as far as your screw settings..the intial settings should be 1.5 turns out from all the way in to start with. Make sure you have the carb gasket on right too.(not rubber to rubber)
1987 Spree 4400 miles 32 mph stock with my 285lb ***
bigbaer
Post by bigbaer »
When I set the screws to the specs in the manual (1 1/2 - 1/7/8 turns out), my poor Spree tries to take off! It revs up really high, and the only way to slow it down is to screw the air screw all the way in, and the idle screw almost all the way in. As for the carb gasket/spacer, it's on correctly. The o-ring looked to be in pretty good shape, too.
uspmale
CARBURETOR
Post by uspmale »
check your throttle.
Linkage and piston position.
Sounds like its hanging up.
greg
darat
Post by darat »
there is a lil slot that u need to put the cable in the slider for the carb.
You put the slide in backwards.
darat
Post by darat »
yeah thats what i ment..
bigbaer
Post by bigbaer »
Shouldn't the slot in the slide be down? I'm assuming so, to make room for the idle adjustment screw. Am I wrong?
berreta22
Post by berreta22 »
there is actually two ways to install the slide..the right way and the wrong way. Make sure you put it in the right way..you will know because the slide will drop farther down one way more than the other.
darat
Post by darat »
yeah if u try to push it then u will brake the lil plactic thing off of the carb and then u got a problem.
