roller weight
paulpauly7
Re: roller weight
Post by paulpauly7 »
what weight have you got in there now?
dun rite
Re: roller weight
Post by dun rite »
check the width of the belt against the specs in the manual. had a similar problem that ended up being a belt close to the minimum spec
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
paulpauly7
Re: roller weight
i cant understand your mumbo jumbo
Re: roller weight
I retract what I said in another thread. The key to good writing is NOT to type every word rattling around in your head, but to cut it down to the words that convey what the reader needs to understand. Or whatever.
The key not to be banned is to refrain from using bad language or insulting the Forum when it fails to give you FREE advice. I think. Maybe.
