1993 honda elite sr 50 with Malossi BBK and top speed issues
rag
Post by rag »
I have a 1993 sr50 with the af05e motor and installed the malossi BBK, I have excellent low end power but top end is running about the same as BBK was installed, 40 mph. I have changed roller weights from 10 grams to 7.5 before the BBk and thats prolly why low in is so good but where do I get my top end from the BBK?
paulpauly7
Re: 1993 honda elite sr 50 with Malossi BBK and top speed is
Post by paulpauly7 »
with a wider belt , aftermarket gear set , taller rear tyre or more rpm from a performance exhaust (not home made unless you actually know what you are doing unlike some)
rag
Post by rag »
already have the taller rear tire 90/90x10
tazland001
Post by tazland001 »
You need a gear ratio upgrade. Get some 9to1's and you will fly.
Taz
bakaracer
Post by bakaracer »
are you running a aftermarket variator?
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
rag
Post by rag »
STILL RUNNING STOCK GEARS AND JUST GOT A KELLI VARIATOR FOR IT
bakaracer
Post by bakaracer »
you should see another 3-5mph more with that variator.
91 yamaha tzr 250r
bfowler
Post by bfowler »
also need a new ramp plate, 25 degrees or so. vt cycles sells sef ramp plate for $15+shipping.
paulpauly7
hit up tru72 hes got the sef ramps
rag
Post by rag »
okay thanks and I did contact daywot as to why no steeper ramp plate and he said kelli variator basically didn't need one that you can just use your stock ramp plate and it will increase speed like that, is that true?
bakaracer
Post by bakaracer »
rag wrote:okay thanks and I did contact daywot as to why no steeper ramp plate and he said kelli variator basically didn't need one that you can just use your stock ramp plate and it will increase speed like that, is that true?
yes. if you have a us2 stamped in the ramp plate. that will work good.
91 yamaha tzr 250r
rag
Post by rag »
okay and if it does not have the us2 stamped in my current stock ramp plate then I should upgrade?
bakaracer
Post by bakaracer »
post a pic of the ramp plate you have.
91 yamaha tzr 250r
rag
Post by rag »
Mine has us72 stamped in it, so guessing thats what you meant
