midrange burbble before pipe kicks in
welder steve
Post by welder steve »
So i got my extra bore honed and ported the cyl to match stage6 streetrace kit, have a 21mm oko,ct,pg long modded. Iridium pkug 7hix. Great bottom end, then just before the pipe hits it makes a weird burble sound and stutters, if mess with the throttle it will hit the pipe and rip, if i stay in the powerband its fine till i drop the rpms any ideas thanks
bakaracer
Re: midrange burbble before pipe kicks in
Post by bakaracer »
what throttle position does it do it at?
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
welder steve
About 1/4 to half
bakaracer
Post by bakaracer »
welder steve wrote:About 1/4 to half
move the needle clip 1 up. that should lean it out a little to clear out that burble you got going on.
91 yamaha tzr 250r
welder steve
Thanks ill try that today, im at a 45 pilot and a 100 main runs like a raped ape once it gets into the powerband
