what size carb can you "fit" on certain size intakes
mmeadows
Post by mmeadows »
https://www.treatland.tv/OKO-26mm-intak ... ke-dio.htm
do i have a little wiggle room here? if i say find a good deal on a 28mm carb can i make it work with this 26mm intake?
i mean if its just rubber connecting shouldn't any carb work if you have the right tube?
Re: what size carb can you "fit" on certain size intakes
Should work. Try and see. $20 aint bad.
paulpauly7
Post by paulpauly7 »
that intake will bolt on top of the reed cage no need for a adapter plate
mmeadows
Post by mmeadows »
to reiderate my queation can i put a 24mm carb on a 26mm intake?
bakaracer
Post by bakaracer »
mmeadows wrote:to reiderate my queation can i put a 24mm carb on a 26mm intake?
yes. you can even put a 19mm if you want.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
