Four Stroking, I Think
My spree will go about 25 mph. When it gets to that speed, the engine stops sounding high pitched and makes a low pitched sound. The speed stays close to the same. While I am going, the bike occasionally has surges where it tries to accelerate, but starts making the lower sound again. Can anybody tell me if this is actually four-stroking and how to fix this.
"Four stroking" is 2-stroke parlence for a miss while running. Engine shakes and misses every other stroke, making little power. Indicates a rich running condition. Mine does this if I don't let it warm up first b/f taking off.
Check your main jet size, needle jet setting per manual, and for a clogged air filter.
Admin, Hondaspree.net
- Farfignugin
Why on earth is your clutch staying locked up?
Cause of this could be bystarter not working/improperly installed, oversize main jet, missing needle jet, or hacked-up intake.
- Farfignugin
