more speed
FullRace808
more speed
Post by FullRace808 »
I want more speed out of my 107cc stroker motor
Af18 block
50mm fully counter crank
And idk wat size of a bore.but its charmo
All ported and matched
7:1 gears
30 oko( 145,58)
Ct chrome
Ncy drive line
Daytona ramp
Polini guides
Zx trans. Ncy torque plate
42.9 weights( 8g, 6.3g weights)
1500 center spring
3000 clutch
3 pole stator
My bike feels like it revs really high and doesn't pull as much.
What should I do?
bakaracer
Re: more speed
Post by bakaracer »
You know for sure the crank is a 50mm stroke? What are the port durations now? What was ported on the bore? What exhaust is being used?
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
JAC3
Re: more speed
Post by JAC3 »
hey fullrace what did you to fix it. i have the same problem 50/50. my other motor 72 corsa mini stroked pull and screams more hard...
i wonder if my clutch is not holding up from mid to top end..my bottom end is really good yanks hard..
tazland001
Re: more speed
Post by tazland001 »
well how fast is the top? And what are you using for a drive face. The aluminum one or stock?
JAC3
Re: more speed
Post by JAC3 »
tazland001 wrote:well how fast is the top? And what are you using for a drive face. The aluminum one or stock?
stock one.
JAC3
Re: more speed
Post by JAC3 »
Max 63 mph GPS..
JJ Joseph
Re: more speed
Post by JJ Joseph »
JAC3 wrote:Max 63 mph GPS..
Man, that's a pretty good rate of knots for a littler scooter!
tazland001
Re: more speed
What roller weights you using. If your revin out on mids and top you might be a bit light on the rollers. We have to start somewhere to figure this out. I have to go will chime in later.
Taz
JAC3
Re: more speed
Post by JAC3 »
tazland001 wrote:What roller weights you using. If your revin out on mids and top you might be a bit light on the rollers. We have to start somewhere to figure this out. I have to go will chime in later.
Taz
i have 7-8grams in now.
tazland001
Re: more speed
Well I thought about this and my conclusion may seem simple but I would like you to try 9gram weights. If the 9's are to heavy you can offset the 8's and 9's together. Here is why. You have sick bottom end so I suspect the rear end set up is right. If you where revin out on the bottom I would assume it would be the clutch spring, the clutch, to light of drive face, or to light of rollers. But its not so try this and let me know.
Taz
JAC3
Re: more speed
Post by JAC3 »
tazland001 wrote:Well I thought about this and my conclusion may seem simple but I would like you to try 9gram weights. If the 9's are to heavy you can offset the 8's and 9's together. Here is why. You have sick bottom end so I suspect the rear end set up is right. If you where revin out on the bottom I would assume it would be the clutch spring, the clutch, to light of drive face, or to light of rollers. But its not so try this and let me know.
Taz
hey taz what do you mean to light or drive face, can i add washer between the ramp and drive face?...i will try the 9s first and will let u know..
JAC3
Re: more speed
Post by JAC3 »
thankz taz i change the drive face with another one i think i had s on, changed the weights to 9 grams and change my clutch.. now hitting 75MPH i think it wants to go faster tho.
patthesoundguy
Re: more speed
Post by patthesoundguy »
That's scarey fast :-)
tazland001
Re: more speed
Glad I could help :)
Taz
JAC3
Re: more speed
Post by JAC3 »
how can i make it go 80+?..
