Premix advice
WeeMan
Premix advice
Post by WeeMan »
So after killing one cylinder I rebuilt the whole engine from scratch. New bearings and seals, a malossi bbk and head. Its got the multivar variator and and LV3 pipe. I have changed the belt to malossi and the centre spring and the clutch springs are also malossi. I left the carb and air box stock but I am finding it impossible to tune. So I have now ordered the malossi carb and filter (think its 19mm). I know I will have to premix. Will it be 32:1 or should I go to 25:1? I presume I can take off the oil pump and the tank once I start to premix?
Its a 1985 UK vision, well just about nowadays :lol:
bfowler
Re: Premix advice
Post by bfowler »
Seems like 32:1 is the golden number around here.
paulpauly7
Re: Premix advice
Post by paulpauly7 »
get a pump plug for a af18 or af16 it will fit your af05e engine that way you can remove the oil pump all together and gain a little case pressure as well .Oh and id go with 32:1 with full synthetic 2 stroke oil
WeeMan
Re: Premix advice
Post by WeeMan »
Thanks for that. Ive already got fully synthetic so thats ok. Just so I am clear if I put 4 litres in the tank I need 128ml of oil?
Cheers
Danny
WeeMan
Re: Premix advice
Post by WeeMan »
Any one know where I can get a Oil Plug from? Im in the UK and cant find one. If anyone can sort me one I can always PayPal.
Cheers
Danny
Re: Premix advice
4000/128 = 31.25. Close enough.
Plugs can be ordered from vendors like DayWOT, VT Cycles, JiangWayne.com. They're 10-$15.
bfowler
Re: Premix advice
Post by bfowler »
http://www.ebay.com/itm/OIL-INJECTOR-PL ... 3f225497ae
I'm going home to Hawaii in 2 weeks and I'm planning to stop by VT cycles to order some stuff for my upcoming build. I can send you one if you cant get one by then. Theres lots of them on ebay as wheelman has mentioned.
Re: Premix advice
Greetongs:
OOOHhh, BFowler! Canya pick me up a Scorpion pipe? And a CT Black? Oh, and a set of MICHELIN S-1s.
bfowler
Re: Premix advice
Post by bfowler »
Wheelman-111 wrote:Greetongs:
Haha I don't know if you are being serious or not :p
But if you are then sure. I get home on May 20th.
Re: Premix advice
I just re-examined my post. I'd like to say that I invented a Secret Code for Joke posts where they start with "Greetongs" but I'll be honest and say it was a typo. If a suitcase full of Arrow, Scorpion, and Hurricane exhausts fit safely in the Overhead Bin, I'd say you could make a killing when you return. But if YOU say that they'll arrest you at the King Kamehamehameha Airport.
JJ Joseph
Re: Premix advice
Post by JJ Joseph »
On my 90cc, I mix 200ml oil in every 10 liters of gas in a gas can, but I keep the oil pump since it keeps everything lubed during deceleration (downhill for example). The oil pump is there for a reason. The total oil ratio, (premix +oil pump) is about 30:1. Buy a cheap CHT gauge while you're doing final setup so you don't toast the thing:
http://www.ebay.com/bhp/traxxas-temp-gauge
You can remove the CHT when you're done tuning, and save it for your next build. It's cheap but won't last forever if you leave it installed with loose wires flapping in the breeze. It's also not waterproof.
With the CHT gauge installed, you'll see that your CHT rises rapidly when decelerating from WOT. That alone should be a clue that you should keep your oil pump.
JJ Joseph
Re: Premix advice
Post by JJ Joseph »
Wheelman-111 wrote: if YOU say that they'll arrest you at the King Kamehamehameha Airport.
Just off-load the stuff from your Cessna 150 at the Lanai Airport :naughty:
