Bigger carb, custom setup?
burnt_toast
Post by burnt_toast »
I have a spare 14.5mm carb from my vento, and I was thinking of retrofitting it to the spree. It wouldn't be a direct bolt on since the vento's carb is slip on, but if it can work I think it might be an improvement. If I happen to make the setup work I can sell it to someone who's interested, since my spree isnt streetable.
What size is a spree's stock carb?
projects galore :nerd:
MySpree
Post by MySpree »
TOAST NICE TO FINNALY HEAR FROM YA!!!! uhh idk a 12?
darat
Post by darat »
i think a 14-15 it is just a guess
burnt_toast
hmm 12 sounds more like it because the slide does looks smaller than the vento's, but I still need to know for sure if its really going to be an improvement.
burnt_toast
there's so many spree owners and no definite answer? I just want to know for sure first, before I begin a project without benefits.
You can pick up a Dellorto or Oni carb that will bolt up in 15mm+ sizes for around $100... is it still worth it?
darat
Post by darat »
well i am sure that u got us to back you up
burnt_toast
noiseguy wrote:You can pick up a Dellorto or Oni carb that will bolt up in 15mm+ sizes for around $100... is it still worth it?
well this carb is free, and I currently don't have a use for it so I thought I'd give it a shot.
darat
Post by darat »
if it dont work then u can allways sell the carb to me. :P
maddog
Post by maddog »
it will not work, the vento is a yamaha based engine and can't be swapped with a honda, you can get a 19mm intake adaptor with a 19mm dellorto carb which is overkill, the spree is a dead end to begin with....
maddog
Post by maddog »
MySpree
Post by MySpree »
so, man u gotta experement. have fun.
MySpree
Post by MySpree »
its liek when i put my 65cc kit on my spree. it started adn ran. didnt run to good but it ran, it had low power due to the 4 mm gap that was in the cylinder cuz the crank was to long, but i bet with machining it would work just fine
burnt_toast
maddog wrote:it will not work, the vento is a yamaha based engine and can't be swapped with a honda, you can get a 19mm intake adaptor with a 19mm dellorto carb which is overkill, the spree is a dead end to begin with....
im not swapping an engine, but the carb. as long as the throttle cable fits and intake is big enough to use the flow increase, i don't see a problem. a carb controls fuel flow, as long as its doing that it'll get fuel to any engine. imo, but yeh might experiment.
MySpree
Post by MySpree »
my aero ran with no carb
