2001 Elite S 50 - Budget Entry Level Mods?
paulpauly7
Re: 2001 Elite S 50 - Budget Entry Level Mods?
Post by paulpauly7 »
you have no choice you ill have to run full premix
W8kbrder
Oil Pump Plug Question
Post by W8kbrder »
When you guys delete the oil pump and run pre-mix, once the plug is inserted and a washer is used to keep it in.....I've noticed there is about 1/8th inch of space between the plug and the washer. When I crank the scooter....I notice that the plug bounces up and down against the washer. Is this a normal thing or have I missed something entirely?
2001 Honda Elite S (De-restricted)
|Prodigy Variator w/ 9g weights|De-restricted Exhaust|Oil Pump Delete|1.5k Center Clutch Spring|2k Clutch Grabbers|.88 Main Jet|2nd Airbox Tab Removed|9:1 gears|49mph GPS confirmed|
No!
You must stack washers to shim it tight.
W8kbrder
Post by W8kbrder »
Never leak tested the plug. Seemed like a lot of people do it. ill just shim it.
