sb50 ct intake???
bjdipert269
- BMX
sb50 ct intake???
Is the anybody on here or commercially thatakes an adapter for the sb50 motor to take a ct intake??
bjdipert269
- BMX
Re: sb50 ct intake???
That makes
Kevinstonge
Tazland001 I believe is still selling carb kits for the spree. Someone else may have to chime in, but I'm pretty sure the kit comes with the adapter, ct manifold, and oko 21mm carb. Not sure if he sells the adapters individually tho..
bjdipert269
- BMX
I'll have to look into it, I have the intake already, I just need to find a way to adapt it
- patthesoundguy
Those adapters are hard to get separately, I have one it came with my taz carb kit its a neat piece. If you were handy you could make one. Some drills and the right metric tap and a block of aluminum.
sb50 ct intake???
You can just use the stock reed cage just cut out the center and match it up to your CT and boom adapter.
- patthesoundguy
I dont think that will work... the reed cage has no way to bolt the ct intake to it. As soon as i can get the pic of the adapter to upload youll see why it possibly wont workcurtis966 wrote:You can just use the stock reed cage just cut out the center and match it up to your CT and boom adapter.
- patthesoundguy
there is the adapter you seek.
there is a reed block next to the adapter and you can see how there is nothing to bolt the ct intake. And the ct reedcage is the same just oposite way round. And the reed block is plastic and would just snap when you hit a bump. Sent from my LG-C800G using Tapatalk 2
bjdipert269
- BMX
Patthesoundguy what was ur top speed out of ur sb50??
- patthesoundguy
I have a 84 spree, it does near 35 stock with intake ported out and sb50 size reed block a mlm pipe and ax 24 belt.
bjdipert269
- BMX
I have a ct intake with the vblock reed will that work better than the sb50 reeds??
- paulpauly7
do you have a big bore kit on it ?If not the intake and a big carb will probably go slower be way louder and use twice as much gas .Doesnt really make any sense to me
- patthesoundguy
If running a carb that's not too huge for the stock cylinder it could wake the motor up but could be tricky to get the balance right. I've been dying to try my ct intake and 21mm carb on my stock cylinder on my spree with the pipe, just to see the results but I haven't had the time. Who knows it might rock with a bigger carb, won't know until someone tries it.
bjdipert269
- BMX
That is what I was gonna try before I did the bbk , I just need to get the carb now
bjdipert269
- BMX
