AF16 whee options - split from "New Elite Build"
Indy Elite
Re: New Elite Build
Post by Indy Elite »
what kind of wheel and hub options are available for the af16 engine? that is really my only real issue.
inkerb2b
Re: New Elite Build
Post by inkerb2b »
U can use a ruckus/met hub but have to use a 10" and no fattys
Indy Elite
AF16 wheel options
12*3?
Re: New Elite Build
Engine case limits both width and height to 90/90x10. Maybe a very low-profile 12" tire could fit in height, but probably too wide. What is the reason for desiring big wide tire? It adversely affects handling.
Indy Elite
Re: New Elite Build
i am not interested in wide. i am interested in larger diameter.
vette76
Re: AF16 whee options - split from "New Elite Build"
Post by vette76 »
i am running a dio style ruckus 10x3 on mine with a 90/90/10 no issues. very close though. for a larger diameter, you would need a sym engine case.
87' spree (SOLD
12' wrx
Indy Elite
100/60/12 is just about 1/4 in larger in diameter than 90/90/10. So if you split that in half, from the axle it should be what about 1/8 in more required room. Does a 90/90/10 have an 1/8in of room between the tire and case?
Installed diameter isn't the same as running diameter. A 3.50 x 10 fits, but rubs at speeds>55 MPH. Centrifugal "growth". Not sure what if any 12" rim hubs fit the splines.
