2 strokes are coming back?!
mmeadows
Post by mmeadows »
mmeadows
Re: 2 strokes are coming back?!
Post by mmeadows »
idk man fuel injected two stokes seem pretty interesting
bushpigwillie
Post by bushpigwillie »
We can only hope they do. I've read that the big mfgrs have been able to pass epa smog tests with fuel injected 2 strokes for a few years now.
*, without injection they were able to pass smog back in the great 80's! Granted it cost and weighed a bit more with the catalytic converters but they could still do it. I'd pay a bit more for an injected RZ350 today! :) Can you say 750 power in a package that weighs 250 lbs!? WOWZA!
2000 Suzuki Hayabusa 1300cc
1986 Honda FrankenSpree 49cc
Goped Trailripper 46cc
Bladez Moby 49cc
patthesoundguy
Post by patthesoundguy »
You can actually get fuel injection kits that would work on a spree, I had found them on the web. I must hunt the link down.
mmeadows
Post by mmeadows »
patthesoundguy wrote:You can actually get fuel injection kits that would work on a spree, I had found them on the web. I must hunt the link down.
s t f u ! does it have an ecu like a car does? i'm interested to see this
patthesoundguy
Yeah it was adaptable to all kinds of small displacement engines.
patthesoundguy
http://www.ecotrons.com/2_Stroke_Small_ ... I_kit.html
paulpauly7
Post by paulpauly7 »
that is friggen awesome nice find pat .You need a pat o the back for that one .Now who has the money to blow on it so we can see how it works .My wife would friggen kill me if i bought that when i have a perfect working carb
I think it's important to draw the distinction between "Port" fuel injection that's been around since the 1950s and the latest
"Direct" injection that squirts Gasoline at very high pressure directly into the combustion chamber, like a diesel, but still with spark ignition. That's the technology, along with recirculation of lubricant, giving 2-strokes a shot at beating Emissions requirements.
tuserv
Post by tuserv »
2 stroke aprilia SR50 scoot had direct injection in 1999 http://www.aprilia.com/en-US/Model/74/S ... nical.aspx
Good find, tuserv. What Aprilia didn't have, and that Rotax, OMC, KTM and others are working on, is a pump-fed lubrication system that doesn't blow the oil as a total-loss system out the tail pipe, into the nose of the Smog Police. Outboards and some snowmobiles already being sold have it. It's a matter of time until someone tries for a Street-Legal vehicle to pass Emissions. Trouble is, the expense of these additional devices bring the cost of 2-strokes back up toward the cams and valve train of 4 strokes. However power should be better for a given engine weight, so don't give up on this yet.
patthesoundguy
paulpauly7 wrote:that is friggen awesome nice find pat .You need a pat o the back for that one .Now who has the money to blow on it so we can see how it works .My wife would friggen kill me if i bought that when i have a perfect working carb
Yeah agreed, that thing is so pricey it makes it not quite a player unless you have deep pockets and are most likely single ;-)
Post by eliteguy50 »
Wheelman-111 wrote:Greetings:
Advancement in atomization of a/f in sdi has kept the 2t limping on. From the performance standpoint, turbo 4t tech has stolen the performance margin from the 2t.
bushpigwillie
So you have to turbo charge to get a 4t to match normally aspirated 2t. Sounds like 2t is still the better power unit!
Bladez Moby 49cc
Turbos bring on a slew of other issues, and the cost of turbocharging must be added to that of the cam drives, valve gear, etc. This makes a considerably more expensive engine. Kawasaki's GPZ 750, Yamaha, and even Honda-san's CX-650 promised liter-class power in a midsize frame. They never quite delivered, and a li'l something called Turbo Lag makes for an interesting ride. :shock:
