Fun Spree build.
Pineapplegti
Re: Fun Spree build.
Post by Pineapplegti »
Sorry .. 8.44:1 gearing ... Corsa .. 28mm oko 135/150 main ..
refl3x
Post by refl3x »
ok what if i'm an idiot and dont know what "corsa" is?
bfowler
Post by bfowler »
refl3x wrote:ok what if i'm an idiot and dont know what "corsa" is?
Polini corsa bbk.
Pineapplegti wrote:Sorry .. 8.44:1 gearing ... Corsa .. 28mm oko 135/150 main ..
wait im confused. in your post it says 60mph and cant wait to get the 9-1 gears. so that 60 mph run was on 8.44?
paulpauly7
Post by paulpauly7 »
ive had 65.2 mph with the 8.44 to 1 gears and nothing is fine tuned yet
refl3x
Post by refl3x »
i noticed a lot of people on here go with the polini kit. my other scooter is mainly polini but how does the molossi compare with the polini? i noticed they have a MHR rep and a "race" version... only difference that i can tell is the way the cylinder is coated. also where are you guys all finding your final drive gears at? i've only seen the 13/35 "top racing" gears.
Pineapplegti
paulpauly7 wrote:ive had 65.2 mph with the 8.44 to 1 gears and nothing is fine tuned yet
Can almost garuntee I have at least 100 lbs on you.. I plan on hitting my scooter yard up tomorrow and grab another af16 drive spindle so I can have both the 9:1 and 8:44 setup. It has more to give I'm sure.. Still on the stock clutch spring as well as the rear main spring and on the junk Chinese pipe.
Malossi "For Dio" kits generally have a bigger boost port requiring carving out the stock AF16 crankcase port to match the gasket for best performance. Polini Cortessa and Corsa kits have AF16-size ports and are more "bolt-on". Subtle porting differences from the Proud Rivals make for slightly different performance results. Bakaracer's 80+ MPH track bike is an MHR, but I suspect tuners can go as fast on a well-tuned Corsa. The Italians are meticulous about clearances and dimensional precision. Pistons are likely to be Quality-Checked to go with the cylinder before they're shipped. Some less-expensive pull a jug out of one barrel and a piston from another and put 'em in a box and call it good.
There are tons of gear sets on eBay last time I looked. Search "SA50" or "Dio". VT Cycles sells all flavors - stock varies.
Pineapplegti
Pay no attn to this...
Got another 1.5 out of it
