66cc BBK Upgrade? Thoughts?
Well, the weather in WI is starting to get nice again (ok, thats a lie, it was nice, and is supposed to rain for a few days..but should get nice and stay nice soon)...so that means its time to get my scooter up and running once again. Its been about 2 years since it was last running..and from what I remember, I had rather low compression and several people suggested I replace the top end.
So, I figured what better time for a BBK; frankly I do not want to spend that much (since that usually leads to spending more), so I figured getting a 66cc BBK (http://www.ebay.com/itm/271036038325) would be plenty since it doesnt seem to require an aftermarket crank, carb or exhaust..
What are everyone's thoughts on this BBK? I'm hoping to order soon so I can start working on it next weekend.
Thanks all!!
~Shiba
p.s. This will be the first summer I'll be attempting to ride it since taking a nasty spill a few years back...so heres to getting back on the saddle!!
edit: Also forgot, probably going to pick up this jet kit (http://www.ebay.com/itm/271200867348) so I've got a few to tweak the carb with..
Thanks all!!
~Shiba
2000 Honda Elite SA50P (AF16E)
Current Mods: 72cc Malossi BBK, Unrestricted, OKO Vari, OKO Ramp, [9g OKO/ 7.5G ???] Rollers, #82 Upjet, ASN 9:1 gears
HELP ME WITH MY TRANSMISSION TUNING!!!
- SpyderMike
Re: 66cc BBK Upgrade? Thoughts?
I ran that bore for a couple seasons with no problems. Where you @ in WI?
Up by Milwaukee..SpyderMike wrote:I ran that bore for a couple seasons with no problems. Where you @ in WI?
Did you just roll w/ the stock carb/exhaust as well? if so, what jetting were you running at?
- SpyderMike
No I was way over carbed with a 24mm...
You going to attend moto-scoot rally on the 1st?
gotcha...SpyderMike wrote:No I was way over carbed with a 24mm...
well, this is the first i'm hearing of it...but sadly i'll be up in the dells camping for a friends birthday, otherwise it sounds like it would be awesome...minus the fact my scooter isnt working of course..
Low compression means it's time for a fresh jug. A 66cc BBK is a good place to start because you don't need to replace anything else except change the main jet to about an 80 or 85. It's not a difficult project. An aftermarket exhaust will add another few mph, but it's not necessary to start withshiba wrote:several people suggested I replace the top end
Oh seriously? That's nice then haha... After reading a few posts I was under the impression that the main jet would be closer to 100...but that would be perfect since I think I've currently got a 82 or 85 key in there... :p
- Red Eft Performance
Just a heads up for twenty more bucks I sell a 72cc malossi kit that is bolt on and you can use stock carb. Quality and performance is double of that 66cc kit. Keith
Red Eft Performance
View products click => Here
can it be used w/ everything else stock (ie, exhaust, etc)? also, what jet size is a good starting point for the stock carb?Red Eft Performance wrote:Just a heads up for twenty more bucks I sell a 72cc malossi kit that is bolt on and you can use stock carb. Quality and performance is double of that 66cc kit. Keith
Yes it can be used with stock parts.
For carb. Airbox intact air screw about 3/4 of a turn out. Needle clip at the top. 100 main. Tune from there.
Red Eft Performance
i think its fairly safe to assume that you mean the second kit on your page here (http://www.hondaspree.net/phpBB3/viewto ... =2&t=19538), correct? does that also come w/ a head, or just use stock? defiantly leaning towards this more now.. sorry for playing 20 questions tho..Red Eft Performance wrote:Yes it can be used with stock parts.
Yes its the second one. Yes it comes with head.shiba wrote:i think its fairly safe to assume that you mean the second kit on your page here (http://www.hondaspree.net/phpBB3/viewto ... =2&t=19538), correct? does that also come w/ a head, or just use stock? defiantly leaning towards this more now.. sorry for playing 20 questions tho..Red Eft Performance wrote:Yes it can be used with stock parts.
Red Eft Performance
cool beans! pm sentRed Eft Performance wrote:Yes its the second one. Yes it comes with head.shiba wrote:i think its fairly safe to assume that you mean the second kit on your page here (http://www.hondaspree.net/phpBB3/viewto ... =2&t=19538), correct? does that also come w/ a head, or just use stock? defiantly leaning towards this more now.. sorry for playing 20 questions tho..Red Eft Performance wrote:Yes it can be used with stock parts.
